Question Arduino Sketch for Sabertooth Fan control
Discussion in 'Miscellaneous' started by _cOdaC_, Jan 29, 2024.
  1. _cOdaC_
    _cOdaC_ New Member
    46Coins
    I have printed this Fan holder for a 2x32 Sabertooth and mounted a 120 fan on top of it.
    The idea is to measure the temperature of the two motor channels and if one of the two reaches 40°C, turn the fan on.
    I am no Coder, so if anyone could help me to add this feature in the SPS sketch that would be fantastic.
    Here is the response of Dimension Engineering I've got so far:
    The actual Arduino USB Sabertooth "ReadBack" sketch shows how to read temperature with an Arduino.
    Download and install our "Arduino Libraries for SyRen/Sabertooth Serial (includes examples)" at the link I provided in the previous reply.
    Then in the Arduino IDE, go to File > Examples > USB Sabertooth Motor Driver > Basics > ReadBack. Then open it. It literally shows how to "getTemperature" in the sketch.
    If you need even more detail, go here:
    https://www.dimensionengineering.co...Library/html/_u_s_b_sabertooth_8h_source.html
    Sabertooth can only read the temperature of the motor channels. Which is in most cases, sufficient for satisfactory operating temperature, as motor temperature is the only meaningful value in determining overall unit operating temperature. There is no temperature reading for the unit as a whole. The thermal shutdown feature is tied to motor output specifically.
    If the ambient temperature is unusually high, then that will affect the output channel temperatures. So thermal shutdown is in effect if necessary.
    Per the 2x32 documentation page 6, "Maximum continuous output current derates linearly above 40C ambient. At 70C ambient the maximum continuous output current is 10 amps
    per channel." So having your fan turn on when Sabertooth M1 or M2 reaches 40C would be prudent.
    https://www.dimensionengineering.com/datasheets/Sabertooth2x32.pdf
  2. Gadget999
    11,670Coins
    You could also use a themoswitch
