2dof simtools and movements
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Mich, Mar 7, 2023.
  1. Mich
    Mich New Member
    - 125Coins
    Hi, I have a problem, when I test movements 2 dof test section
    Pitch and roll make same thing, rig only roll even I slide pitch control, what is wrong.
    And how I get test joystick plugin, it not seems work att all, I have patched it
    thanks.
    154,720Coins
    +11,193 / 57 / -2
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    The Dir boxes in Axis Assignments determines which way each axis moves, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    The Joystick plugin page provides the basics for setup:
    How to use:
    Run GameManager in Admin mode.
    Select the "game" Joypad.
    Patch by selecting the installation directory of SimTools.
    The patch installs a program "SimTools_Joystick.exe" and "SimTools_Joystick_Recorder.exe". These programs do nothing than trigger SimTools to read the Joystick values.
    Run GameEngine & GameEngine.
    Run SimTools_Joystick.exe or – if you want to record the data – run SimTools_Joystick_Recorder.exe.
    Play with your joystick and observe the values in TuningCenter.
    The FAQs provide information to extend and customise the actions of the Joystick plugin: https://www.xsimulator.net/communit...otion-plugin-and-vjoy-controller-mapping.291/
