Question First 2DOF SIM Rig with issues 24V wheelchair Motors
Discussion in 'DIY Motion Simulator Projects' started by Bjoern, Feb 18, 2024.
  1. Bjoern
    Bjoern New Member
    44Coins
    Hey,
    I have some issues with my first Sim Rig projekt.
    my Setup:
    2x 24V Wheelchair Motors 250W 75rpm
    2x IBT_2 BTS7960 43A Dual H-Bridge
    1x Arduino Uno
    1x 800Watt 24VDC Powwer Supply
    I have done the wiring and and have load the sketch to the Arduino.
    My issue is that both motors are only spining in one direction. I have tested several settings in the SMC3 Tool and always the same results only one direction. I had checked the wiring three times.
    Pherhaps the mode in the Arduino is "MODE2".
    Maybe the IBT_2´s are brocken but both?
    Any Ideas what going on here?
    Thx and Regards
    Bjoern
    152,677Coins
    +11,104 / 56 / -2
  3. Bjoern
    Bjoern New Member
    44Coins
    yes the pots are working fine, if I spin them with my hand i can see every little motion at the SMC screen, and of course they are connected to the Motors.
    Here are a video of my issue:
    152,677Coins
    +11,104 / 56 / -2
    It does not look like everything is properly centered at rest before calibration.
  5. Bjoern
    Bjoern New Member
    44Coins
    yes, in the video is was not centered, but it makes no difference if centered or not.
    Here a video with centerd position of the pot
  6. Bjoern
    Bjoern New Member
    44Coins
    If i swap the cables at Rpwm and Lpwm at the motor controllers should the motor spin in the other direction?
    Because nothing happens if i do this.
    152,677Coins
    +11,104 / 56 / -2
    Try testing the IBT2s with a multi-meter, to see if they work as expected.
    If so please set Fpwm to 25 and do the calibration sequence from scratch, then post the result, including the value of PWMmax when the motor begins to move:
    8. Set Kp to about 400
  8. Bjoern
    Bjoern New Member
    44Coins
    Ok, somthing is strange
    If i do the setup routine and set the Parameters as in the description the motor is spining.
    The yellow line (PWM) is staying at 0 but the motor ist spinning. PWMmin and PWMmax are at 0.
  9. Bjoern
    Bjoern New Member
    44Coins
    Also when i set KP to 0 i can spin the motor, whats is wrong here?
    152,677Coins
    +11,104 / 56 / -2
    Did you test the IBT2?
  11. Bjoern
    Bjoern New Member
    44Coins
    Yes, the ibt_2 are working only in one direction. When they had do reverse i messure 0Volts at the Motor pins.
    I also messured the PWM pins, there it seems all is fine. The voltage increase when i spin the pot away from center and decrease when i spin it to the center position. This works in both directions.
    I guess the IBT_2 are defect, but i am perplexed that both are defect.
    Have u got an explanation about this:
    152,677Coins
    +11,104 / 56 / -2
    A number of members have reported faulty IBT2s, so manufacturing standards could be an issue, as they are built to a price.
  13. Bjoern
    Bjoern New Member
    44Coins
    The twoIBT´s are broken, i changed them and everything works.
    Thanks for the support
