DCS with SimTools
Discussion in 'Digital Combat Simulators (DCS)' started by Aviasimserver, Aug 26, 2023.
  1. Michael Pleym
    Michael Pleym Member
    258Coins
    Thank you, I will do that.
    Strange that DCS don't have an setting to play the sim in window mode. Like in other games. But anyhow, I'll turn down the resolution and see if it helps.
    Michael
  2. Michael Pleym
    258Coins
    I've tried to turn down the res and have that way enabled to have both window mode DCS and Simtools open on the same screen (although focus for moving inputs can only be in one window at the time ofc). And no, no movements/values in Simtools Max/Min tuning screen when moving the stick in DCS at all. Just zero's in the input line.
    Reading the posts about udp-settings in the main thread, I'm beginning to wonder if that could be the problem for me too. How can I find those settings and what should it be for DCS?
    Kind regards
    Michael
  3. Grand Strate
    Grand Strate New Member
    - 51Coins
    Good morning
    I have exactly the same problem as Michel.
    Since I switched to Simtools 3 it no longer works.
    I never had a problem before on the old version of Simtools.
    I have no problem with other simulations (except WRC Sport)
    What interests me at the moment is to run my engines on DCS
    Has anyone found where the problem could be coming from?
    I still have the old DCS plugin, but I think it's the same one installed in Simtools 3
    153,131Coins
    +11,117 / 56 / -2
    The v2 and v3 plugins are not compatible, if that is what you mean. So I am just checking that you installed the DCS plugin from directly inside the plugin manager in v3?
  5. Grand Strate
    - 51Coins
    Hello @noorbeast.
    Thank you for wanting to help me.
    I am using the latest version of the DCS plugin for simtools 3.
    Motion inputs are 0 in flight. However, simtools detects DCS well.
    I have no movement issues with my other games.
    I tried simtools 2 again which is still installed on my computer. it does not work either
  6. Grand Strate
    - 51Coins
    Oui j'ai installé le plugin avec le gestionnaire de plugins simtools 3
    Voici mon dossier Lua
    153,131Coins
    +11,117 / 56 / -2
  8. Gard Haug-Hansen
    Gard Haug-Hansen New Member
    76Coins
    I have the exact same issue as described in this post. Did someone find a solution?
  9. Grand Strate
    - 51Coins
    Hello.
    Unfortunately no, I still have the same problem. Good luck
  10. John Murphy
    John Murphy Member Gold Contributor
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    There are several steps to validate and troubleshoot the problem...
    1) validate that your interfaces are set up correctly by using the "test settings" function in the interface setup
    2) validate that your DOF's are setup correctly using the "test settings" function in the DCS motion settings
    3) validate that simtools is actually connecting to DCS (the plugin changes to say "stop")
    4) validate that simtools is receiving telemetry from DCS (you get changing values in the max/min screen)
    5) validate that you have proper values in the min/max to get motion
    Other things...
    - ensure axis limiting is set up properly
    - ensure that enabled is set
    - make sure you know how to configure the 'on ground' settings vs the 'in air' settings that you are tuning the right one:)
    if you know which step (1-5 above) is the issue, then maybe someone can help troubleshoot. I can confirm that it does work when everything is setup correctly.
    153,131Coins
    +11,117 / 56 / -2
    Please see my earlier post: https://www.xsimulator.net/community/threads/dcs-with-simtools.18100/page-2#post-247583
    SimTools v3 is in Beta and under active development, so please post issues to the dedicated v3 thread for dev visibility, consideration and hopefully resolution: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/
  12. Gard Haug-Hansen
    76Coins
    Thank you! Its a bit frustrating and all other games work seamlessly.
    I did a lot of testing yesterday and I can for sure say that simtools do not receive telemetry from DCS.
    I tried to uninstall/install the pluging in both the c-drive/win/steam/steamapps/dcs and the c-drive/user/save games/dcs (from memory).
    Where should the plugin be installed so I at last eliminate that. However it didnt work either place.
    Thank you.
  13. Michael Pleym
    258Coins
    Hi guys,
    The latest update of the plugin with fix for the region issues did it for me. Works like a charm now at my end.
    Hope you can find a solution soon.
    Kind regards
    Michael Pleym
  14. Gard Haug-Hansen
    76Coins
  15. Michael Pleym
    258Coins
    Yepp, v 3.0.
    The plugin update is v 10.
  16. VAJDAKOS
    VAJDAKOS New Member
    - 23Coins
    Hello! I have the same problem as others! I checked the settings, verified the test movements... everything works, the plugin also switches to "RUN" mode, but no telemetry data is coming from the game. Neither in DCS nor in War Thunder! Could you help? (Sorry for the English, I'm using a translator.)
