Question DOF-Reality H3 Stuttering
Discussion in 'Commercial Simulators and Peripherie' started by LeNinjaHD, Mar 24, 2023.
  1. LeNinjaHD
    LeNinjaHD New Member
    Cologne, Germany
    79Coins
    3DOF, Motion platform
    150,722Coins
    +11,018 / 55 / -2
    Can you please post pictures of all of your SMC3 settings.
  3. LeNinjaHD
    Cologne, Germany
    79Coins
    Fpid / 10, Kp = 120, Ki = 1, Kd = 10, Ks = 5, PWMmin = 0, PWMmax = 180, PWMrev =200, Max limit = 50, Clip Input = 190, Deadzone = 0 (The default settings)
    150,722Coins
    +11,018 / 55 / -2
    Please post a picture of your SMC3 setting running Sine test.
    When following the SMC3 setup instructions at what PWMmax value (Step 9) does the rig start to move: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    8. Set Kp to about 400
  5. LeNinjaHD
    Cologne, Germany
    79Coins
    77A21D3C-582F-4849-A0AB-733DC7C7D049.jpeg 079ACC13-CAAB-45E3-90B9-44AA776B0552.jpeg
    It starts to move at 40.
    I attached are my settings and running sine.
    150,722Coins
    +11,018 / 55 / -2
    Try kp at 400, pwmmax and pwmrev at 100 then run Sine.
  7. LeNinjaHD
    Cologne, Germany
    79Coins
    Still stuttering.
    150,722Coins
    +11,018 / 55 / -2
    Can you please post a picture of SMC# running Sine with those settings.
  9. LeNinjaHD
    Cologne, Germany
    79Coins
    Will do in a few days, because the sim is at my local gliding club, and I cant drive there every day unfortunately. If you have anything else that I could try out, please let me know!
    150,722Coins
    +11,018 / 55 / -2
    Try kp at 400, that should improve tracking, but I am just guessing, as the whole point of the SMC3 utility and live interface is to allow for tuning settings specifically for your hardware.
  11. Alan Moriarty
    Alan Moriarty New Member
    12Coins
    Hey dude did you get a solution to this ? Mine doing the same thing ?
  12. LeNinjaHD
    Cologne, Germany
    79Coins
    Hi Alan,
    unfortunately mines still not working and support isnt really helpful.
  13. Alan Moriarty
    12Coins
    That's not ideal , I'm in the middle of chasing mine up so il let you know how I get on . The motors were working fine with mine until the Uno went down ( which I replaced and got Flashed by support) so I don't think it's a motor problem but a software issue . Happening to both my motors as well but in opposite directions.
  14. LeNinjaHD
    Cologne, Germany
    79Coins
    Same for me, Ill also try to contact support again as i didnt have time in the last few months.
