DIY Compact 6DOF Wiper 24V <200EUR
Discussion in 'DIY Motion Simulator Projects' started by tadek, Nov 13, 2020.
Tags:
  1. tadek
    tadek Active Member
    574Coins
    First step bootom floor
  2. tadek
    tadek Active Member
    574Coins
    Side wall Sheet metal 2.5 mm
  3. tadek
    tadek Active Member
    574Coins
  4. tadek
    tadek Active Member
    574Coins
  5. tadek
    tadek Active Member
    574Coins
  6. tadek
    tadek Active Member
    574Coins
  7. tadek
    tadek Active Member
    574Coins
  8. tadek
    tadek Active Member
    574Coins
  9. tadek
    tadek Active Member
    574Coins
    7 wheels for the seat as a chassis
  10. tadek
    tadek Active Member
    574Coins
    wheel fastening
  11. tadek
    tadek Active Member
    574Coins
    Hi
    I looking for
    Potentiometer with magnetic sensor
    to the wiper motor?
    how best to fasten?
    150,968Coins
    +11,025 / 56 / -2
  13. tadek
    tadek Active Member
    574Coins
    Hi
    Should the wires to the pot will be shielded?
    Wich the wires should be shielded?
  14. tadek
    tadek Active Member
    574Coins
    it is good idea?
    150,968Coins
    +11,025 / 56 / -2
  16. tadek
    tadek Active Member
    574Coins
    wiperservo modification
    and cut off the mass
    before:
  17. tadek
    tadek Active Member
    574Coins
  18. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    thats my video...for dof i use different config, just a cylinder (3dprinted) with 2 magnet glued on the big gear...and the hall sensor, i make the mount using acrylic, just glued permanently...and the sensor mount, attached using spacer in the back of gearbox...
  19. tadek
    tadek Active Member
    574Coins
    fixing the potentiometer:
    drilling a hole
  20. tadek
    tadek Active Member
    574Coins
    threading
