WIP - RacingMat's closed circuit Gseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Dec 16, 2019.
  1. RacingMat
    21,082Coins
    i really think the delay was in the flow of air in the small diameter tube...
    the sensor was close to the bladder but motor was overreacting because of the delay. It could be fine for other use than simracing which requires reactivity...
    but yeah, checking auto-average is a good point
    +1 (I had to deal with this issue for an altimeter on a DIY water rocket)
  2. Gadget999
    12,156Coins
    a water rocket ?? what do you do for a job ?
  3. RacingMat
    21,082Coins
    yes water rocket is fun, reusable, not incendiary, ecological (but still dangerous)
    it was the student project of my son!
  4. blekenbleu
    blekenbleu New Member
    121Coins
    Have you found some pressure pad with larger diameter tube than others?
  5. RacingMat
    21,082Coins
  6. blekenbleu
    121Coins
    So, flow restriction delays and distorts "original signals",
    can be somewhat compensated by an old trick called digital pre-emphasis:
    • Deploy servos and pressure pads that can displace more air than needed at the seat
    • Servo can initially displace a larger (or smaller, when decreasing) value than wanted
    • Then servo signals are relaxed to wanted values after some delay, as air transfers nearly complete
    • Some initial trial-and-error tuning is wanted to derive best delay and weight values
  7. RacingMat
    21,082Coins
    oh! I knew about PID but not about pre-emphasis: I'll look at it. Thanks
  8. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    any development with your project ?
  9. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    How u connect servos and psu to arduino on 7 volt? Do need motor controller?
  10. blekenbleu
    121Coins
    Arduino has a library to control (by PWM) hobby servos, which have 3-pin connections:
    1. ground - connect to servo power and Arduino ground
    2. PWM - connect to Arduino PWM pin
    3. power - connect to e.g. 7.4 VDC supply, separate from Arduino power.
    My 7.4VDC power derives from a 12VDC bulk power supply reduced to 7.4VDC by a buck regulator.
    I chose a buck regulator which also limits current (to less than 5A)
    and has supercapacitor bank between the buck converter and servo for peak (e.g. stall) currents.
    Separate Arduino power is by its USB connection.
    Hobby servos do not require motor controllers.
  11. Krzysztof Dej
    Poland
    1,100Coins
    I d
    I don't know if I understand well. My English is not so good. Psu connect to external psu port? And serwo to 5v pin?
    I have also another problem on game engine I have surge force on axis assignment b and set in tuning center to work only for throttle. But how set sway force on 2 serwos to work like left right if I have 2dof on a assignment? If I set on b assignment like max 3 min 0 it's only work for one side. Is any way to set 2 serwos, one work in minus, and one in plus?
  12. blekenbleu
    121Coins
  13. Krzysztof Dej
    Poland
    1,100Coins
    I have a regulated 12v power supply, when it gives 7 volts and connect it as you wrote, nothing happens. Should I set it to 12v and connect a regulator like this?
  14. blekenbleu
    121Coins
    12V[​IMG] will damage hobby servos.
  15. blekenbleu
    121Coins
    corrected wiring for your regulator
  16. Krzysztof Dej
    Poland
    1,100Coins
    @noorbeast I think maybe U can help? Maybe a modified arduino code? I have met several times with such ones, but which one should i choose?
    153,914Coins
    +11,156 / 57 / -2
    If you are using RC servos then @eaorobbie's code is the way to go, see the instructions and code links here: https://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
