MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. noorbeast
    153,053Coins
    +11,117 / 56 / -2
  2. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    550Coins
  3. absyfadhel1
    bahrain
    550Coins
    Btw just now i finish replace all wires...so its like new now...in simtools test the position that motor move is good but ingame the position move more than it should be why?..i tried to use tunning center but i didnt get anything from it...i follow the tunning center steps but nothing changed
  4. absyfadhel1
    bahrain
    550Coins
    How do i make motor get higher when the output position right there?
    153,053Coins
    +11,117 / 56 / -2
  6. absyfadhel1
    bahrain
    550Coins
    153,053Coins
    +11,117 / 56 / -2
    Changed what wire...asking a question without providing details about what was done, for what reason, resulting in what behavior is not really helpful.
  8. absyfadhel1
    bahrain
    550Coins
    as i said before that i have been changed all wires from arduino and so....
    how much weight can this motor take ? https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    is it good enough?
    153,053Coins
    +11,117 / 56 / -2
  10. absyfadhel1
    bahrain
    550Coins
    153,053Coins
    +11,117 / 56 / -2
    The instructions are bottom left of the SimCalc window measure as directed in the instructions:
  12. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Did you solve this problem?
  13. absyfadhel1
    bahrain
    550Coins
    No!i didn't
  14. Krzysztof Dej
    Poland
    1,100Coins
    Did u set windows language us American?
  15. absyfadhel1
    bahrain
    550Coins
    hi guys...i searched everywhere for the email address to contect https://www.motiondynamics.com.au
    but i didnt found it...the worm drive i want its not in stock and i want to email the company to ask about the motor and when its will be in stock...i tried to send massege through the contect from the website but no one answer from 3 month...help please
  16. absyfadhel1
    bahrain
    550Coins
    153,053Coins
    +11,117 / 56 / -2
    Looks to be a compact design, so torque matters more than linear lever speed.
    You can leave room for options but I suggest you start around 50-60mm for lever CTC and max angle of 38-40 degrees, as over that effective torque utilisation declines rapidly.
    You want to maximise motor position Y within the footprint of your design, it is hard to say if you have or have not done that looking at the SimCalc entries, perhaps a quick drawing of your intended rig would help.
  18. absyfadhel1
    bahrain
    550Coins
    i forget to tell you that the motor in front not in rear its make diffrent?
    153,053Coins
    +11,117 / 56 / -2
  20. absyfadhel1
    bahrain
    550Coins
    so you advice me to purchase the motor or no? because i was using wiper motor and it was moving great but need more power so i think this motor will give more power right?
