Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
  2. yobuddy
    50,833Coins
    There is also a $29.99 upgrade option to get a pro license should you have a DIY one already.
    Simply login to SimTools.us, and under your account click 'view license'.
    Then click 'view upgrade' next to your diy license and you can upgrade.
    btw, your v2 license will also work for v3 when its ready to rock... :thumbs
    Take care,
  3. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Ok I’ll take a look , big thanks
  4. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    I tried to log into Simtools.us but it would take my log in details ( I tried to use these xsim ones )
    Do I need to register there & then somehow make it know that I have a DIY licence ?
    151,712Coins
    +11,045 / 56 / -2
    Normally you would use the email you purchased/got the Licenses with (likely your Xsimulator email), and if you don't have a password for the SimTools site then click reset password.
  6. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    Hello, good night. I know that i have a pro license and a game vibe option available, but i have a questions about this program:
    I need a two sound cards to manage a vibrations and game sound? With only one card is posible to manage vibrations and sound with headphones?
    And another question:
    I need an audio amplifier or something similar?
    Thanks!
  7. Bastiuscha
    Bastiuscha Active Member
    750Coins
    If you play with monitor, you need a second soundcard. An Bassshaker with audio amplifier. Or a buttkicker, as a all in one solution.
    151,712Coins
    +11,045 / 56 / -2
    There are software options like Voicemeter that let you manipulate audio, but to be honest the best solution are ultra cheap USB audio cards from the likes of Ebay: https://www.ebay.com/itm/392857008108?hash=item5b781a37ec:g:AmoAAOSwv9hW3USI
    Use a suitable Amplifier for the transducer specs, personally I use these compact 100w amps from Nobsound, with a 3D printed mount for driving two 50W transducers each: https://www.aliexpress.com/item/32949992384.html?spm=a2g0s.9042311.0.0.27424c4dWOn7Bf
    But there are cheaper options, for example the Wondom 4 x 100 Watt Class D Audio Amplifier: https://www.ebay.com/itm/143317208188?epid=1170283882&hash=item215e5f0c7c:g:ct8AAOSwT75ZlVxu
  9. long legs
    teacher
    catalonia
    373Coins
    Thanks Noorbeast, now i ll focus to solve the problem with Assetto corsa and when be solved i will try this wonderful new world inside simtools. Thanks a lot!
  10. long legs
    teacher
    catalonia
    373Coins
    excuse me @noorbeast have you got links of your transducers?
    If i understand correctly, with this mini Usb 3d sound cards you can control the vibrations with game vibe?
    I think that ill buy this amplifier, seems good quality, but i hve to buy the source power in the same store separately. Thanks!
    151,712Coins
    +11,045 / 56 / -2
    I have one Buttkicker Advance: https://pagnianimports.com.au/collections/buttkicker/products/buttkicker-advance-transducer
    And 4 Dayton 50W bass shakers: https://www.daytonaudio.com/product/1245/bst-1-high-power-pro-tactile-bass-shaker-50-watts
  12. long legs
    teacher
    catalonia
    373Coins
    thanks! you have 2 amplifiers nobsound i think, for 4 dayton's.
  13. noorbeast
    151,712Coins
    +11,045 / 56 / -2
    Yes I do have 2 Nobsounds for the 4 Dayton's, I have also tested another running the Buttkicker, which it can also drive.
  14. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Hello! I have some problems when i try to capture the high/low in the tuning center. I cant edit the numbers or type in the value i want ? Capture High is no problem, but when i capture Low, it also saves the highest captured value in the Low "window" ? I guess you want the lowest value in the Low, and mabye even a bit lower then the lowest captured value.
    151,712Coins
    +11,045 / 56 / -2
    You can click on the colored box next to the Axis in the Tuning Center to change its mode Green is Balanced so both values are the same, Blue is Capture and Pink is Off and you can even enter different Max/Min values if you want.
  16. Mver
    Mver New Member
    47Coins
    Motion platform
    I purchased 2 bass shakers and an amplifier and knowing that i have Game Vibe I thought it would be a piece of cake to have it start running. But no.
    I am using a usb stero sound card (for headphone) connected to a mono amplifier (Reckhorn) which has 2 shakers serial connected.
    In Game Vibe I can select the ""2 USB PnP sound device" and with the audio tester I get the test sound. However if I start AC I get no sound(shake) from the game. Only a very soft rpm sound that is hartly detectable. Messing with the volume in Game Vidbe doesn't do anything. Tuning Center is showing min/max data when I rev the engine for example. SO that looks good. Game is patched.
    I tried everything but nothing helps.
    Now i found out that not all Simtools versions support Vibe.
    I am not sure which version of Simtools I am running, startup screen says: Version 02.4.0 but my download history file says SimTools_v2.4.
    So my question are:
    • Would it be the SimTools version or could it be something else I am missing.
    • If I do an uninstall and install a new version would I delete all my motion settings and patches?
    Thanks, Mark.
  17. Blekkulf
    Molde
    342Coins
    I had the same problem. Just downloaded the simtool install file and re-installed. Did not loose any presets
  18. noorbeast
    151,712Coins
    +11,045 / 56 / -2
    The SimTools splash screen shows the version and you should upgrade to the latest version: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    From your description it is not clear if you have fully configured GameVibe, as like creating a motion profile GameVibe needs to have a profile for the vibrations you want to produce for a particular game, please see the manual: https://simtools.us/wp-content/uploads/2019/06/GameVibe_v2.0.zip
  19. Mver
    Mver New Member
    47Coins
    Motion platform
    Ok thanks! Do I first delete the old version and then re-install new or can i install it on top of the old version?
    Ask this because I am afraid to loose my presets.
    Thanks for your support!
    151,712Coins
    +11,045 / 56 / -2
