  1. noorbeast
    153,053Coins
    +11,117 / 56 / -2
    I am not sure what you mean, I suspect you are asking if the existing single PSU is adequate for 4 motors and my guess is that it likely is not.
    Please elaborate if you mean something different.
  2. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    if you were wondering if that source supports all 4 engines ..... thanks. the ideal would be a source for two engines.
  3. Peter_the _machinist
    Peter_the _machinist Member
    Mechanical Engineer (CAD,CAE)
    Poland, Gdańsk
    359Coins
    Hello everyone!
    I'm new here and I want you ask all of you about SimTools game manager->SimTools game engine ->SMC3 utility connection problem. If it's wrong place to do so please redirect me to suitable forum place for it. But:
    My connection built is:
    PC master: SimTools game manager & SimTools game engine
    <->UDP connection
    PC slave: SMC3 utility and Arduino UNO with SM3 in it
    I've managed to send data and read them in SM3 utilty with Output Testing for all of 3 motors but when I hit a run in Life for Speed there is no output to do SM3 utility on PC slave. Game is patched and Game manager is connected to Game engine. I see prompt "game running" in Game manager and in Game engine. I suppose there is a problem with my axis assingment. Here's some screenshots from my setups upload_2020-12-7_0-31-52.png upload_2020-12-7_0-32-26.png
    I'm after only one day of setting this up so it can be totally bullshit ;).
    At current state I'm in design process of building my 3DOF motion platform. I'm planning to put 12V or 24V wiper motors to simulate accelerate in a car and feel of traction loss (I supposed that is Yaw DOF(?))
  4. Chris Chopping
    Chris Chopping Member
    Mechanical Engineer
    Melbourne, Australia
    - 26Coins
    Hi Peter_the _machinist,
    Have you followed the general guide (in FAQ) in using the simtools setup? That guide helped me alot.
    Running the game in output testing in the virtual mode shows also if it is patched correctly and values are being spat out.
    I have a 2DOF racing sim and i use surge and sway rather than pitch and roll as you get more feeling. Pitch and roll is good for track surfaces and flight sims but you can barely feel it in racing sims
    153,053Coins
    +11,117 / 56 / -2
    Just to clarify, you can't run the SMC3 utility and SimTools at the same time, as that would cause a port conflict.
    You also need to have run LFS before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    The simplest setup for Simtools 2 to test everything is via Serial:
    Interface Type - Serial
    ComPort = the Arduino ComPort, you can find it in Windows Device Manager.
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    If you want a 2 PC setup then grab a copy of the SimTools manual: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    And see the FAQ tips here: https://www.xsimulator.net/community/faq/dual-pc-simtools-setup.251/
  6. Peter_the _machinist
    Poland, Gdańsk
    359Coins
    Dear noorbeast, thank you for your reply.
    I need to disagree with you, about port conflict because I did manage run SMC3 utility and simtools at the same time, but as I said not on one PC. I'm sending data via UDP to my second PC and everything working great on output testing but the problem is that I've run LFS one time patched it then everythins seems to be set up and connected but I cannot get output data when I play the game. In fact I don't know how to use axis assignments. I don't exacly know what % value mean there. I saw that some of users use same type of DOF for different axis, but dunno what for. I'm basing on racingcube fasetech early(stage of kickstarter) construction, maybe it will help to understand what I'm trying to do. Here's screenshot from my arduino-connected PC with SMC3 utility running.
  7. Peter_the _machinist
    Poland, Gdańsk
    359Coins
    Dear Chris Chopping, thank you for your reply.
    I think you are right about forces to get from game. I simulating G forces of a car by pitch and roll of motion platform but forces to get from game should be surge and sway. I will try to patch the LFS one few more times and try to get output data on virtual axis at least( I did not managed to do so yet).
  8. Peter_the _machinist
    Poland, Gdańsk
    359Coins
    Hi, I've managed to get the data to SMC3 utlity! The problem was probably that I've close the game repatched it and then run once again instead of close the game unpatched it run the game then close it and patch it. Thank you very much and till next bug! ;)
    153,053Coins
    +11,117 / 56 / -2
    Grab a copy of the SimTools manual, as that will help you understand how to configure SimTools: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    There are also helpful member configuration tips in the FAQs: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    In particular check out how to refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  10. Chris Chopping
    Mechanical Engineer
    - 26Coins
    Let me know if it works!
  11. Peter_the _machinist
    Poland, Gdańsk
    359Coins
    It work like a charm, thank you! :D.
    I have another question. Probably to @RufusDufus if he is still here. I was wondering is there a way to set UDP output mode as a standard/automatically after utility start up. I Have small industrial computer as my SMC3 utility runner and after whole configuration proccess I would like to make it plug and play. I want to turn on the computer without screen and that's why I want it to sending data to arduino automatically.
  12. Jakob Carron
    Jakob Carron Member
    34Coins
    Hi this is an amazing tutorial. I am having a problem with this though. I am making a 2dof project with 2 of the Chinese motor controllers. I have them all wired up right and I have imported the smc3 code to my Arduino. I set up the com ports in the smc3 utilities. When I put in all the settings on smc3 and turn on my motors they don't turn on no matter what. Also in the top left it will never let me turn on my motors on smc3 @noorbeast could you help at all?
  13. noorbeast
    153,053Coins
    +11,117 / 56 / -2
    You have not given any details of what motor controllers are being used, are they supported by SMC3 and if so are you using the correct Mode in the SMC3 code?
  14. Jakob Carron
    Jakob Carron Member
    34Coins
    I am using 2 ibt-2 h bridges and I have set it to mode 2
    153,053Coins
    +11,117 / 56 / -2
    From the instructions: Slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
  16. Jakob Carron
    Jakob Carron Member
    34Coins
    When I go and turn up the pwm max the motor does not move at all. Also in the top left it doesn't ever say that the motor is on
    153,053Coins
    +11,117 / 56 / -2
    You click the button top left where it says Off to turn the motor On.
  18. Jakob Carron
    Jakob Carron Member
    34Coins
    When
    When I do that it just flashes on then goes back off. I think it might be a wiring problem. Is there any way I could check that
  19. Jakob Carron
    Jakob Carron Member
    34Coins
    I am now finding out that with my other motor and controller when I turn on the power supply it runs my motor through my motor controller no matter what
    153,053Coins
    +11,117 / 56 / -2
    The wiring for IBT2s is in the first post of this thread:
