Problems with my simulator
Discussion in 'New users start here - FAQ' started by Perramf2020, Oct 20, 2020.
  1. Perramf2020
    Perramf2020 New Member
    79Coins
    2DOF, 3DOF, Arduino
    Hello, very good trust, everyone, the reason for my message is because I am building a 2dof simulator, the problem that it presents is that when testing the motors they only rotate on one side, I can't get the motors to rotate on both sides, check the connection and everything is fine, the signal from the potentiometers in the smc3utils program runs fine but the motors only go to a single address, which could be the problem
  2. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    the motors are coupled with the potentiometers ... ?? You would have to upload a couple of photos to see how the potentiometers are set and for them to pay attention you would have to write or translate into English.
  3. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    first of all someone can explain something to me: I have seen that they say to enter the smc3 code in mode 1 or in mode 2 that they refer to? Is it not a single code or do you have to clear and exit the mode to be configured?
  4. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    the SMC3 code is a code that is loaded into the arduino and once loaded into the arduino you would have to download the SMC3 utility to couple the motors with the potentiometer the code is the standard 3dof code that we all use once I do all this you would have to look at how to couple the motors .. and once coupled you would have to configure the game engine well put in port that you are using the same parameters of the photo then continue configuring everything in the axis part in the axis assingnament flap when you open a game there is if the engines would have to go up and down simulating braking or accelerating or when you turn to both sides.
  5. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    I continued to see everything an internet video highlights everything as it is done in the video but at the time of testing the potentiometers with the program sif I move the manual potentiometer the motor moves but if I set it to level dr the blue line stops but It only goes to one side, I already checked my connection and everything is fine, the potentiometer goes up and down in the program but the motor only goes to one side. which may be?
  6. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    You have to sign a video, your problem is in the first configurations from the beginning in the steps to dock the pot .... the SMC3 3DOF code is loaded correctly in the arduino.
  7. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    Could you help me tell me how the configuration is?
    and do you know how I should set the potentiometers at what level?
  8. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    This is my conection
    153,914Coins
    +11,154 / 57 / -2
    By any chance are you using wiper motors and are the pots connected to the motors?
    Mode 1 and Mode 2 depends on what motor drivers are being used with the SMC3 code, Mode 1 for the likes of Motor Monsters and Mode 2 for the likes of IBT-2 boards: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    That wiring looks to be correct.
  10. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    It is very right noorbeast it may be that you have the monster mode1 and not the ibt2 when you load it and make sure you loaded the correct mode to the arduino I have no problem helping you couple the motors it seems complicated but it is very simple yesterday I think you were You in the private conversation and I asked you if you were from Argentina, if you want, I will leave you my number so that you can send me audios when you are connecting them. I await your answer.
  11. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    Sounds perfect to me, do you speak Spanish? Send me your number so I can send you photos and audios, very kind of you.
  12. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    I am using wheelchair motors.
    my connection is made with arduino and ibt2
  13. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    I followed all the steps in this video.
    https://www.google.com/url?sa=t&sou...BMAF6BAgJEAE&usg=AOvVaw2fL0k6YlZiyZIyDeC8EDki
  14. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    153,914Coins
    +11,154 / 57 / -2
  16. Perramf2020
    79Coins
    2DOF, 3DOF, Arduino
    no, I don't know how to do it. I just downloaded the smc3 and uploaded it to the arduino
    153,914Coins
    +11,154 / 57 / -2
    If you are using IBT-2 then the SMC3 code must be changed to Mode 2 in the code like this:
  18. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Of course, as you say in that part of the code, it says that you have to clarify the way you use, you are right. I think that in the video you put as a reference, it never clarifies that the code must be reformed.
  19. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    When you want to understand something, it seems to me that you need to re-read the instructions several times; I also didn’t understand exactly where to change the code the first time.
  20. elfren
    elfren New Member
    18Coins
    Tengo un conflicto con el sensor. Lo que pasa es que en vez de marcar todo el parámetro en la configuración de smc3, solo marca una parte y cuando estoy usando el 2dof se desconfigura porque supera el límite. Tengo mi licencia. Simtools pensé que sería por esto pero sigo con el mismo conflicto
    La última imagen, que es diferente a las tres primeras, es una imagen tomada de un video en el que se puede ver donde la línea verde que hace referencia al sensor recorre toda la trayectoria del motor ya que este es un caso diferente al mío donde el motor apenas llega a la parte superior y cuando pasa el punto donde llega mi línea verde, Se apaga y deja de funcionar hasta que lo configuro.
