Full Frame 2 DOF + Traction Loss new build
Discussion in 'DIY Motion Simulator Projects' started by Halloween2go, May 20, 2020.
  1. susocalfail39
    susocalfail39 Member
    GALICIA, ESPAÑA.
    50Coins
    Very ingenious, now I understand, those at the waist already hold you all the time and shoulder straps let's say they make a plus in the braking effect, very ingenious and cheap, good idea, thank you.
  2. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,407Coins
    Well I certainly can't take credit for this.. I saw it on BoostedMedia's YouTube site. And he got the idea from one of his subscribers.. But I will say, It adds to the immersion weather you have VR or not. Having those shoulder straps crank down on you when you are braking!
    151,700Coins
    +11,045 / 56 / -2
    It is actually a very common harness setup of many members here.
  4. Halloween2go
    1,407Coins
    yeah I figured you guys have already set this up.. Hey! That's why I added it!.. Really like it too!
    Hope your project is going good and thanks for 'keeping an eye on this forum'... Dmax
  5. Halloween2go
    1,407Coins
    I finally upgraded my motherboard, proc and ram from an i3 to an older I-7 that my son gave me after he upgraded his pc.. This thing is pretty good now..
    I7 3960x cpu LGA 2011
    noctua NFU12S fan setup
    Asus P9x79 WS MB with 32GB ram.. It can hold much more but I found one of the DIM slots to be not functioning so for a MB from 2012.. not too bad.
    Here is an update video on it and the motion platform working.. video is in 1080 so it should be pretty clear
  6. Halloween2go
    1,407Coins
    Tuned up the SIM... Racing action at Riverside Raceway. 3 DOF Arduino, Crab Pot motors (working just fine) 55 hours of racing in.
    Check it out. You 'CAN' build something like this.. Just go for it.. DMAX
  7. Halloween2go
    1,407Coins
    70 Hours into the Sim and very little issues. Every now and then one of the Hall effect POTS has a loose connection to the arduino (possibly due to vibration..*always seems to be the same thing every 50 laps or so). So I have decided to solder everything to the bottom of the arduino as my next upgrade. Either way, here's a video from today featuring a Shelby Cobra (pretty powerful) at Imola, italy.. Let me know if you like it DMAX
  8. ChubbyWeasel
    ChubbyWeasel New Member
    USA
    65Coins
    I bought a used computer years ago and when I took it apart I found the previous owner had put some stuff on the connectors to keep them becoming not connectors :). It was almost like really old chewing gum in consistency but easy to clean. I wish I knew what that stuff was because it seems like it would be perfect for this sort of application.
  9. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    well done with your build
  10. Halloween2go
    1,407Coins
    Hi, so even if you don't have a 2080 or 3080 TI card, you can still have some fun with a DIY RIG..
    Here's a video of the Rig (even with a spin out) so you can see it in action. I am going to be doing some upgrades next week on the RIG (soldering the arduino, and some fanatec pedals) but for now I am just using some super basic pedals and steering wheel.. Take a look if you have a chance .. DMAX
  11. Halloween2go
    1,407Coins
    Yeah I know what you mean. Every time I add something, I keep tweaking it to keep it performing correctly. I recently added V-3 pedals and whoooo Man..! I had to rebalance the whole rig! :D
  12. Christian Doehl
    Christian Doehl Member Gold Contributor
    Germany - Bavaria
    677Coins
    I know this from phtography to fix parts for making a photo. I have seen it on amaz... as
    Walimex 300g Modeling Clay Value Pack
    Just as a reference, I'm quite sure it's available from other suppliers as well.
    BR
    Chris
  13. Halloween2go
    1,407Coins
    So I saw a message from TAZ about my settings.. A little more pitch roll and sway.. So I added a bit more sway. So far pitch an roll are very low (I drive in VR with Rift CV1 - so it seems ok to me).. I set the sway to 17..
    Here's a video on starting up the rig if Ya'll are interested. DMAX
  14. absyfadhel1
    absyfadhel1 Member
    bahrain
    448Coins
    Can i get motor link?...i saw this one
    https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    But i didnt found and email address to text them...did you bought it from there?
  15. Halloween2go
    1,407Coins
    I bought the crab pot motors from canada. I got them on EBAY. They seem to be working fine for me after 1 year. I thought the shipping for the motion dynamics motors was way out of bounds so I did not buy the motion dynamics motors . Here is a link to EBAY for the motors I bought from PGSAW
    https://www.ebay.com/itm/GEAR-MOTOR...157992?hash=item5684db6428:g:A0EAAOxyW1NRER~7
  16. Halloween2go
    1,407Coins
  17. Halloween2go
    1,407Coins
    Finally got around to building my control box, instead of just having the arduino's and wires just hanging out everywhere.
    I was experiencing intermittent issues with the hall effect pot being read by the Arduino and always solved the issue by re-seating the wires. But that was a pain. So decided to solder all the connections on the Arduino but leave the IBT-2 connections as 8 pin connectors.
    Here is a photo BEFORE I did the Rework (and you can see it in action in my videos) upload_2021-1-26_17-54-24.png
    I have a 120MM fan blowing on the IBT-2’s. You can see this was kind of an “initial” Proof of concept build for me. So now here is a photo of the new build. upload_2021-1-26_17-54-57.png
    So Here is my Solution. 120MM 12v fan blows on the IBT-2 fins. The Arduino and other connectors are in the Black Box. Also have a Celeron Fan Blowing at the other side of the IBT-2’s. I also reworked the wiring a bit as you can see in the next photo. upload_2021-1-26_17-55-34.png
    So Here I should have the ability to pull out an IBT-2 if it burns out (pretty easily) All the IBT-2 power wires are pretty small 8 AWG, but that’s what comes with the crab pot motors so that’s what I used. I have shielded wires from each Hall-effect POT. All wires to the Arduino are soldered. I used (old soundcard 10 pin connectors) to wire from the Arduino to the IBT-2’s.
    Also have several 12V sources also connected to power both fans and an additional 12V for the wind sim option up front of the rig.
    Initially, my rig grew from 2 DOF to adding the third IBT / motor combo for Traction loss. I was excited to get everything working so I just cobbled everything together. This was my first serious effort at getting it a bit more reliable. Right now I have about 20 minutes testing but no real running in so we will see if I need to make any more holes to vent heat. To me, it looks much better. But the proof will be in ‘reliable operation’ .
    I’ll post a video on youtube send it here this weekend. DMAX
  18. Halloween2go
    1,407Coins
    Ok, So I have YET to get the Monster Moto/SEAFLOW 250CFM blowers going but, I do have the 2 x 120mm fans working. Here is a video on setting up my SIM for NoLimits 2 Rollercoaster.
  19. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    Hello Friend. I wanted to replace the motomonster with ibt_2. I followed the diagram I am attaching. to test I connected all the cables but only a motor and a potentiometer. when I try with SMC3 the motor only moves on one side. what could you be wrong? thank you
    151,700Coins
    +11,045 / 56 / -2
