Icy7CE
  1. Icy7CE
    Icy7CE Active Member
    USA
    2,878Coins
    You could try adjusting the packet rate in the config file (located in the AppData folder at SimTools/MFS2020/SimConnect_UDP_config.txt). You might just have to turn down the graphics of the game, though.
  2. Zeraxx
    Zeraxx Member
    188Coins
    Awesome work Icy, I have the steam version and this plugin worked right off the bat, that being sad I do have the issue of the motion stopping after a few minutes.
  3. caddyboy0103
    caddyboy0103 New Member Gold Contributor
    11Coins
    Restating everything seems to have fixed the issue
    Thanks for the response! Can you explain how that value works? Does going higher with the value slow things down or is it the opposite? Sorry for the ignorant question.
  4. Icy7CE
    USA
    2,878Coins
    The value is the number of times per second that motion data is sent to the plugin. In theory, a higher value means smoother motion, but if it's too much for your computer to handle it could wind up slowing the game down. It's also probably hard to distinguish much of a difference above 100 times per second.
  5. Aron de Haas
    Aron de Haas New Member Gold Contributor
    - 117Coins
    Took the bin files but getting errors, not sure what is wrong;
    *** UDP application for SimConnect to SimTools communication ***
    14:48:57: Packet rate is 10 Hz
    14:48:57: Sending packets successfully
    14:54:24: Open exception: Arithmetic operation resulted in an overflow.
  6. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I cant seem to find SimConnect.dll. What i do find is Microsoft.FlightSimulator.SimConnect.dll. This does not patch for me. Any suggestions. (this is the MS version not Steam.)
  7. caddyboy0103
    11Coins
    You have to enable the developer mode in general settings. Once enabled, you will see a menu at the top left hand side of the screen. Under the help menu there should be an SDK submenu from which you can select install SDK. Once it’s downloaded, you can install it, and the files are installed in C:\MSFS SDK, from there I can’t remember where, but simconnect.dll is there.
    additionally, the plugin author includes simconnect.dll. It’s located in appdata\local\simtools\msfs2020
  8. caddyboy0103
    11Coins
    I get the same error at 100hz, then the sim stops moving.
  9. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    thanks so much:)
  10. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I turned on Developer mode but the is no help menu or sub menu. i also rebooted and looked again. Developer mode is on with no other menu or options. Any suggestions? thanks
  11. craigN
    craigN New Member
    - 131Coins
    hopefully this image helps, it links to an auto download
      54.4 KB
      530
  12. Camerus
    Camerus Sim builder
    California
    46Coins
    Motion platform, 4DOF
  13. Aron de Haas
    - 117Coins
    Doesn't matter which rate i get the error in 5-10min after running.
    currently running the other version, which doesnt have this issue
  14. Camerus
    Camerus Sim builder
    California
    46Coins
    I have noticed that the plugin crashes when you are trying to tune your settings in the Tuning center. It seems like doing it while the game is running causes crashes. Also you should lower UDP bit rate to 60 or 70.
  15. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    It absolutely did. I missed it at the top of the screen as the print was so small. thanks so much for your help. :)
  16. Camerus
    Camerus Sim builder
    California
    46Coins
    Which version doesn’t?
  17. Just 4 Artist
    Just 4 Artist New Member
    127Coins
    Hi, thanks you so much for the plugin. I’m an amateur and it is so difficult to understand How to install it with SimTools.
    Could somebody post on YouTube a quick tutorial video to install the plugin?
    Thanks.
  18. Icy7CE
    USA
    2,878Coins
  19. Icy7CE
    USA
    2,878Coins
    Thanks for the feedback, everyone. I think that all the errors I've seen posted can be attributed to bugs that this update fixes. Make sure to re-patch the game so that all the files are updated.
    Let me know if you run into any more issues!
  20. Icy7CE
    USA
    2,878Coins
    From what I've seen online, I think that the file Microsoft.FlightSimulator.SimConnect.dll can provide the motion data in the same way as SimConnect.dll. The new update looks for either file in the MFS installation directory. I don't have the MS Store version of the game, though, so let me know if there are issues.
