Surge design
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Les Call, Jul 6, 2020.
  1. Les Call
    Les Call rotax 912
    retired
    81Coins
    Hi Guys .I want to add a forth motor for surge to my rig and am looking for details of what other people have used for moving fowards and backwards wheels ? slides ? gears? any idears pictures would be helpful if there are any .
    Les.
  2. dododge
    dododge Active Member Gold Contributor
    854Coins
    Some designs use guide rails and carriages. I think Bajer's rig does this, and there is at least one other brief discussion with video of another rig.
    JCL sells a rail system as part of their D-Box motion package but it's expensive. Sim Racing Garage did a review of it that shows the details:
  3. Pit
    30,490Coins
    I'm using rails, but it's tricky to set up especially when using vr. Also it depends the game and how you prefer the way of acceleration. While sway was easier to configure, surge needs a lot of testing and adjusting in Simtools, SMC3, etc. At least if the rig is moved completely very powerful motors are recommended.
  4. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    I use one of these high powered servos:
    They are only £60 or so and give an astonishing 110kg/cm of force. I use mine on top of my Hexapod as a seatmover. I use it with a bar connected to the seat to move the seat fractionally closer to the steering wheel on braking and a little further away on acceleration. This is as well as the whole rig moving with surge.
    The effect is not for everyone as some want there to be no movement between the seat and pedals/steering wheel to ensure they can brake accurately but with subtle movements (I've set mine only moves the seat a maximum of 3cm or so) I feel it really adds to the feeling of braking and acceleration which the motion rig doesn't provide on it's own even with a G-seat. There are different benefits to be had from motion rigs, G-Seats and seat movers. I can't stop adding and wanting more! I remember reading on this forum how once you start, you get sucked into a spiral of adding and tinkering for ever more - How very true! o_O Maybe a G-Skull next...
  5. Les Call
    Les Call rotax 912
    retired
    81Coins
    Hi .Thanks for the thread about the surge movement and the pic of your motor .Yes your right once you start making one of these you cant stop trying to add things .I use mine for flying or should i say i seem to get more enjoyment out of building it i am fortunate to own my my aircraft so am trying to get my sim to work as well as it can try and be like i am flying if that makes sence . its nice to get a message from someone in our neck of the world .I would be very interested in seeing how you have managed to get the slide part to work i have bought a pair of heavy duty draw runners and am at present trying to work out how to get everything to work space wise .I went down the route of large motors that i bought from Australia but now have found a good supply of Caravan moving motors that are the same as the ones i bought and only cost me only £65 pounds on Ebay.if possible could you send me a pic of your rig with the slide engineering threw this site or PM me, i intend once i have got it finished to put a car system together as well as a flight one so it might be good to pick your brains at some further point if you dont mind .
    All the best
    Les.
  6. GWiz
    GWiz Active Member
    Dentist
    1,509Coins
    Hi Les,
    Its nothing terribly fancy and I haven't neatened anything up yet (I've ordered a 3d printer and intend making an enclosure to house the servo PCB and controlling arduino board)
    I've attached some 6mm threaded rod to a couple of male clevis parts and attached these with washers and nuts to the servo wheel near the back of the chair and a strip of aluminium attached to the chair mounts with a bolt sticking down near the front of the chair. I found the threaded rod could flex a little under strong braking so stiffened it by running it through some 8mm aluminium tubing. With some fiddling, I found the whole range from 0 to 180 degrees on the servo was more than required, so I've set it to only move between about 45 degrees either way. It gives a subtle movement forwards and backwards relative to the wheel and pedals but that's all I wanted, too much feels unnatural. I initially had hooked up a 40kg servo I had lying around. It wasn't powerful enough but convinced me that the surge effect of the seat moving added to the hexapod movement I was already getting was worth pursuing.
    For the sliding motion, I'm just using the standard seat rails normally used for sliding the seat forwards and backwards for adjustment. As it's just a prototype, I haven't even removed the seat adjustment bar - its held in the up position with a zip tie! Very professional I'm sure you'll agree. I'm sure drawer runners or similar could be used instead, anything that keeps the friction to a minimum.
    The servo is attached with a bent piece of aluminium to form a bracket, it's probably sitting a little higher than it needs to be but the bottom of the seat still clears it when it moves backwards (just!)
    Happy to have my brains picked but I'm very much a tinkerer, there are others on the forum with engineering, electrical and programming qualifications who may be able to give better advice! It's an excellent forum though and there are lots of people who are very helpful and happy to give advice and share ideas.
  7. Gadget999
    12,035Coins
    do you have a link to the servo motor ?
  8. GWiz
    GWiz Active Member
    Dentist
    1,509Coins
  9. wingert
    wingert Active Member
    678Coins
    4DOF
    SFX_surge.JPG push pull moded SFX 100 motor
  10. bodays
    bodays New Member
    33Coins
    Hi Wingert,
    I know it's an very old post, but as I'm wondering to create such push/pull behavior to my simracing seat, could you please tell me where did you get this picture ? Hoping that I'l lfind also the additional information (design, electronic, and so on...)
  11. Misanthrop
    Misanthrop Active Member
    652Coins
    It´s an normal actuator which is also used an many different brands like eracinglab, Simmetrik, SFX, PT-actuator, Lebois and more. Mostly with an AASD Driver and Controller like Thanos.
    Just search for Surge at Project area and you get many different Rigs and Solutions
  12. bodays
    bodays New Member
    33Coins
    Thanks for taking time to answer.
    Wish you a good day and good weekend in advance
  13. wingert
    678Coins
    4DOF
    The basis of the actuator is the SFX 100 project (only push)
    https://opensfx.com/
    this Video shows the principle of the SFX push/Pull mod. First version with 6 srews.
    this video shows the easiest way to get the desired slider with the only necessary 2 holes and 2 screws.
    additional you need a collar such as this, drilling out to 30mm with two 5,5 mm bores
    https://www.maedler.de/Article/6231...5CdI_Evsrb58purbuiRxKrXjtm278ZkWJ1O6IvPu9GM_y
    Software could be FlyPt mover Controller Code arduino mega this
    https://www.xsimulator.net/communit...o-mega-for-aasd-15a-and-similar-driver.14421/
    I hope it is understandable
