do-it-yourself static 2dof dynamic conversion
Discussion in 'DIY Motion Simulator Projects' started by pfm21, Jun 17, 2020.
  1. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    Hi everyone. after reading a lot in your forum I'm starting the construction of my dynamic posatzione.My materials are:
    arduino board
    motomonster to control the two engines
    2 10k potentiometers
    24v 30A power supply because the three-crystal motors are 24V
    two 24V truck wiper motors to be replaced later as they are different
    I hope to find help to be able to complete my project
    meanwhile, thank you all in advance
  2. pfm21
    374Coins
    I followed the scheme for the connection between arduino and motomonster and loaded the arduino code SMC3 now I am trying the utility for setting the engines
  3. pfm21
    374Coins
    in the tests that I am doing my difficulty is to connect the potentiometers to the motors as they often move in the tests. do you have any idea?
    153,101Coins
    +11,117 / 56 / -2
  5. pfm21
    374Coins
  6. pfm21
    374Coins
    I forgot. the potentiometers are 10k, perhaps too sensitive?
  7. Jrank1
    Jrank1 New Member
    - 9Coins
    Turn all your K settings to zero except top one. Reduce PWMmin to zero and start again.. motors are always working if they are holding the levers in position..
  8. pfm21
    374Coins
    Thanks friend. I try it.
  9. pfm21
    374Coins
    [QUOTE = "Jrank1, post: 200659, membro: 37341"] Porta tutte le tue impostazioni K a zero tranne quella in alto. Ridurre PWMmin a zero e ricominciare .. i motori funzionano sempre se tengono le leve in posizione .. [/ QUOTE]
    I put all the k settings at 0 as you told me but I can't turn off the motor LEDs. is there no way to enlarge the central dead center of the potentiometer? thank you
  10. pfm21
    374Coins
    this is a picture of motor and utility
  11. pfm21
    374Coins
  12. pfm21
    374Coins
    I ask this because sometimes it doesn't work and I have to open smc3utility first and then I restart everything and then it works
  13. pfm21
    374Coins
  14. pfm21
    374Coins
  15. pfm21
    374Coins
    tihis is my progress.
    thanks to all your advice slowly I'm building my workstation
  16. pfm21
    374Coins
    this is a link with test. for now all right . next step is buiding iron plate to put under the seat.
    I would like to make a platform like this if I can
    this is video test
  17. pfm21
    374Coins
    my next step will be to change the parameters of the axes a bit but I will have to study enough because I still haven't understood many things. but I still thank you all who are helping me a lot.
  18. pfm21
    374Coins
    if one of the two motors rotates a little slower what value should i change? thank you
    153,101Coins
    +11,117 / 56 / -2
    It looks like these are not identical motors,is that correct, as the one on the left looks larger than the motor on the right? If so they may well have different speeds and ratios, which would make tuning really difficult.
  20. pfm21
    374Coins
    yes they are actually different I thought it was possible to change some parameters for the rotation. at this point I have to buy two the same. what do you think of these: https://www.ebay.it/itm/Motor-elett...195446?hash=item420a646df6:g:7JMAAOSwsWddOo7t
