Project kart 2 dof recycling.
Discussion in 'DIY Motion Simulator Projects' started by Renaudeau, May 9, 2020.
  1. Renaudeau
    Renaudeau Member
    116Coins
    Birth of the project:
    During the confinement of the coronavirus I could not go to karting. I look in my
    attic and I found my old PS2 with the game Gran Tourismo3 !!!
    I bought an old Logitech driving force pro for a few € and started playing.
    Having a kart and a few pieces lying around in the rig, I decided to improve my gaming experience by making a
    playseat with what drags me.
  2. Renaudeau
    Renaudeau Member
    116Coins
    The old swing has found a new life by turning into a chassis, an old kart tub repaired with fiber, Ikea chair legs
    , a few pieces of wood and screws.[​IMG]
  3. Renaudeau
    Renaudeau Member
    116Coins
    Attaching the seat with Ikea children's chair legs[​IMG]
  4. Renaudeau
    Renaudeau Member
    116Coins
    The distance from the steering wheel and the seat are adjustable with screws so that my children can also play.
  5. Renaudeau
    Renaudeau Member
    116Coins
    By putting myself back in video games I switched to assetto corsa to test the simulation on PC at a lower cost.
    Realism and scenery in video games has evolved between PS2 games and current games.
    Being in automotive mechanics I can easily have spare parts. So the idea of going 2Dof came to me.
    By searching a little on the net, I saw that there was a lot of project with an arduino and window wiper motors.
    The idea is to make a 2 DOF simulator with the maximum recovery in order to discover the world of programming.
    At first I ask about the components to find:
    I already have the arduino, the potentiometers, the front wiper motors of the car, the rods, the steel tube, a universal joint.
    I hesitate between the motomonster and the 2x32A sabertooth to drive the motors. For the moment I prefer sabertooth for its
    voltage versatility and high intensity.
  6. Renaudeau
    Renaudeau Member
    116Coins
    I'm going to take advantage of the confinement to order my engine control card. What is the best card?
    - Motomonster
    - Sabertooth
    - Other model
    152,045Coins
    +11,062 / 56 / -2
    Cheap clone MMs can be hit or miss: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    Sabertooth is pretty bulletproof, but that comes at a cost.
    There are some other options, JRKs are pretty easy to set up, but also a bit pricey.
    Members are starting to also experiment with other controllers.
  8. Renaudeau
    Renaudeau Member
    116Coins
    Some little news:
    Today I got 2 valéo wipers (12v).[​IMG]
    To carry out my first tests, I ordered inexpensive Moto monsters. If it is successful, I will buy a sabertooth card.
    152,045Coins
    +11,062 / 56 / -2
  10. Renaudeau
    Renaudeau Member
    116Coins
    Thank you for the information.
    I modified my 2 motors to isolate them. I keep the 2 speeds to test.
    I would follow the tutorial to check that the monster motorcycles are working :thumbs
  11. Renaudeau
    Renaudeau Member
    116Coins
    Today I received the Chinese monster motorcycle cards.
    I tested the 2 cards with my multimeter then with the motors.
    Only one card works properly.[​IMG]
    152,045Coins
    +11,062 / 56 / -2
  13. Renaudeau
    Renaudeau Member
    116Coins
    today I carried out my first functional test with the Arduino software then with Simtools demo.
    I followed the forum tutorial and everything went well, well almost ...
    The engine n ° 1 works correctly and reacts well, the engine 2 tends to move back and to seek a little its final position after each command.
    In addition motor 2 has less movement than motor 1. I measured the voltage in A0 and A1 of my arduino
    when I put the motors in the middle position (command R7FL7F).
    I find 2.1volt on A0 and 2.9volt on A1. Is it normal not to have the same values on the outputs of my potentiometers?
    152,045Coins
    +11,062 / 56 / -2
    I have mentioned these before -
    Are the motors ground isolated: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    Has the clone MM been tested: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    As an aside MMs need active cooling.
  15. Renaudeau
    Renaudeau Member
    116Coins
    Thanks for the reply, I think I found the source of the problem. I reduced the speed of the motors and now the 2 motors work well and take the same positions.
  16. noorbeast
    152,045Coins
    +11,062 / 56 / -2
    Now that you have them sorted any updates and pictures on mounting the motors to the rig?
  17. Renaudeau
    Renaudeau Member
    116Coins
    Last week I made the base of the simulator.
    I used used 30 x 30 mm square tube (3€ for 5 tubes of 1150 mm).
    The frame is 1150 x 550 mm.
  18. Renaudeau
    Renaudeau Member
    116Coins
    While I was in the workshop I also prepared the motor plates with 7.5 mm thick flat iron.
  19. Renaudeau
    Renaudeau Member
    116Coins
    I cut a 470 x 100 mm flat iron that will serve as a connection between the gimbal and my seat.
  20. Renaudeau
    Renaudeau Member
    116Coins
    I got a cardan from triumph spitfire.
    After cutting it, I welded it on a 100 x 100 mm plate.
    I will add reinforcements when the tests are finished.
