2DOF on JRK12V12 [POLAND]
Discussion in 'DIY Motion Simulator Projects' started by Peter24, Apr 22, 2020.
  1. Peter24
    Peter24 New Member
    34Coins
    2DOF, DC motor, Arduino, JRK
    Sorry for my bad English
    During last few weeks with corona time, I start to prepare 2DOF beginner project.
    My inspiration took from Erwan960 GREAT project: https://www.xsimulator.net/community/threads/diy-2dof-simulator.4793/
    Specification:
    - Fanatec CSL seat
    - old Fanatec wheel CSR Elite
    - 2DOF main frame make on industrial aluminium profiles (mainly on 80x40mm standard)
    - DC motors DOGA 269.4104.20.04 12V DC Motor 1800rpm 0.8Nm
    Nominal current 20A
    - worm gear 30:1 Motovario NMRV
    - Jrk 12v12 USB Motor Controller with Feedback
    - 10k +/- 10%, linear +/- 1% potentiometer SP22E
    I will share step by step progress of my work, this evening...
  2. Peter24
    Peter24 New Member
    34Coins
    Today I just prepare rest of mechanical parts.
    1. Kardan joint from MTZ tractor:
    and two brackets will are really easy to mount to flat surface:
    I had to prepare adapter to mount on 80x80 alu-profile
    [​IMG] [​IMG]
    2. Upper link mounting set
    150,542Coins
    +11,017 / 55 / -2
  4. Peter24
    Peter24 New Member
    34Coins
    Thanks !
    O sh... I focused on to much how to mount exist Fanatec chair to the alu-profiles. I did not consider this very important factor ;-/
    I will check how to minimize this gap.
    Thank You for this tip.
  5. Peter24
    Peter24 New Member
    34Coins
    Some small progress of my job.
    Gear mounting
    Shaft insertion
    Motor positioning...
    Potentiometer coupling preparation. I use ABS tube. On the motor side I glued below type of nut.
    Prepare steel bracket for potentiometer
    Bracket final concept
    Short break and relax with blend
    Motor joint preparation and final installation
  6. Peter24
    Peter24 New Member
    34Coins
    First parametrization of JRK 12V12
    1. Feedback settings
    2. Motor settings
    3. PID tuning result
    Small overshoot is not so critical in this control plant.
    In Errors page I can see fast increasing "Feedback disconnect" error. Is it normal? I have the same behavior on both JRK.
    150,542Coins
    +11,017 / 55 / -2
    Nice to see you included the essentials :cheers
  8. Peter24
    Peter24 New Member
    34Coins
    Dear Guys, I just stop my project on first test in SimTools. I just try to find similar problem & solution and I finally give up.
    Please support me with below problem.
    JRK utility is working fine but in the SimTools I've notice Protocol Communication Errors. On the real plots You can see that motor moves but not according to the Variable Roll which I change in the Simtools Axis.
    Please check it in below movie. You can see my settings. Please support me.
  9. Peter24
    Peter24 New Member
    34Coins
    I just find the reason by myself. I have to change Output Bit Range parameter. Every post which I read, there was 12bits. I have change to 7 and errors dissapear!
  10. Peter24
    Peter24 New Member
    34Coins
    I just finish settings all parameters.
    Result on below movie. I will be grateful for your comments.
  11. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Hi Peter ,,,you only have one axis assigned in simtools interface settings,,,,, on the interface output use
    [A<Axis1a>][B<Axis2a>]
  12. stevemontuno
    1,461Coins
  13. Peter24
    Peter24 New Member
    34Coins
    Thanks for answer. This interface output commands are for Arduino method of control. As You can see my project use Pololu.
    thx.
  14. Peter24
    Peter24 New Member
    34Coins
    Today I focused on electronics part. I was really supprised that Pololu made so small terminals for such big amperage. I did some adapter for main power cables (3.5mm2).
    For this purpose I have use 2.5mm2 hard wire and aluminium wires connection tube. After proper clamping and fill the gaps with solder.
  15. stevemontuno
    1,461Coins
    Ok if you say so dude .
  16. noorbeast
    150,542Coins
    +11,017 / 55 / -2
    If you are using JRKs then the Interface Type in Interface Settings should be set to JRK. You then configure the device number, Assigned Axis and Output Rate (10ms). Do that for Interface 1 and 2 in the tabs.
  17. Peter24
    Peter24 New Member
    34Coins
    I've read a lot that JRK heat dissipation is really big and they need propel cooling. I decided to use PC coolers. Problem is that on PCB we have capacitors close to ST motor driver.
    In this case I've use thermal pads.
    Final result:
  18. Peter24
    Peter24 New Member
    34Coins
  19. Peter24
    Peter24 New Member
    34Coins
    Today I decided to add one more feature = Traction loss axis ;-)
    I chose motor from Oper Corsa power steering:
    Simple sketch:
  20. Peter24
    Peter24 New Member
    34Coins
    I just finished mechanical part for Traction Loss axis.
    JIG for holes making in the profiles:
    Two steps drill:
    Traction Loss rotation point (self-aligning bearing and shaft):
    Main "H-shape" frame with wheels:
    Frames connection:
    Supporting steel wheels:
