Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    Hello Noorbeast, download dirt 2, elite y dcs world, dirt 2 and elite work, thank you very much again for your great action,
    Greetings Australians from Argentina, from the other side of the world and that everything improves, it will be soon.
    My rig 2dof ideal for race game but not for aircraft games
  2. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    199Coins
    Doesn't work for me. Is there anything i must do with the DirtRally2_MaxMin.cfg file? Drove one race like instructed.
    Installed patch to location C:\Users\tinos\OneDrive\Documents\My Games\DiRT Rally 2.0
    No motion, is there anything i'm missing? Maybe a small read me file would be nice with some instructions what to do with the downloaded plugin files. Iracing and LFS works perfectly fine.
    153,884Coins
    +11,154 / 57 / -2
    Do you have a 32 or 64 bit version of Windows: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Is there data in the top row of the Tuning Center when DR2 is running?
  4. Tino.Sturlic
    199Coins
    Thanks for reply. I have 64 bit. Can you please explain, maybe with a picture where should i look for the data in the tuning center? i have game menager and game engine. Nothing to see there...
  5. Tino.Sturlic
    199Coins
    153,884Coins
    +11,154 / 57 / -2
  7. Tino.Sturlic
    199Coins
    Please check this video
  8. yobuddy
    51,535Coins
    @Tino.Sturlic,
    You have no min/max file for the game buddy.
    All of the min/max settings are zero.
    You need to click "Capture Max Min", and then drive a lap carefully not hitting anything.
    And then click "Save New Settings".
    At which point you should get movement buddy.
    Take care,
  9. Tino.Sturlic
    199Coins
    Man, i did not now you must do this at all. For some reason i didn't have to do it for Iracing but this might be the reason why i had to bump gain in settings to get enough motion. Anyways it works now. Thanks!
  10. bierzor6
    bierzor6 New Member Gold Contributor
    - 35Coins
    Thanks. !!!!!!!!!!
    Great work
  11. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    Hello, first of all, thanks for your work with this plugin.
    I have a basic question. All the people has the same values in the tuning center? Or similar? When I take the values, I saved the values, but with a lot of decimals. When the values are near to zero, the forces are high?
    Thanks!
    153,884Coins
    +11,154 / 57 / -2
    Motion profiles should be dialed in for individual sims, so will vary, see these tips for refining your motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    The smaller the Tuning Center value, and it can even be less than 1, like for surge in some games, the sharper the repose, over a smaller range of movement.
  13. long legs
    teacher
    catalonia
    373Coins
    Thanks for the quick answer friend. Now ill post a picture of the Tunning Center values. There is a problem with a sway, because, I can only feel the vibrations of the actuators, but nothing more. I think that sway is a lateral movement, truth?
    In Axxis put a value of 30% alone, with no more forces to feel if this Sway is correct in tunning center, but i haven't found the solution. The tuning says a value of 4-4 aprox, and it tryed diferents values in TC and the same, a vibrations or not movement at all.
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Your tuning centre numbers look to high, have you tried to capture max min ?
  15. long legs
    teacher
    catalonia
    373Coins
    Yes i captured the min max in TC but moving near to zero for sway and 4-4 and can only feel vibrations, but no lateral forces.
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    you need 2 things to get at least some basic movement,
    1. an high enough DOF%
    2. low enough max and min setting
    so if you have some small movement there i would say start to increase your DOF % a bit at a time and only enable 1 DOF at a time get that set then move to the next:thumbs
    153,884Coins
    +11,154 / 57 / -2
    This is a tuning issue, not really a plugin issue.
    It would be better if you posted pictures of all of your settings on your own thread, that way members could assist without cluttering up the DR2 thread.
  18. inat
    inat New Member
    57Coins
    can i use for 1.3 simtools?
  19. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Simtools v1.3 is no longer supported.
    But I guess if you could make your own plugins then I guess it would still work.
    153,884Coins
    +11,154 / 57 / -2
    No, SimTools 1.3 is depreciated and plugins that were made for are no longer maintained, plugins for SimTools 2 are not backward compatible with 1.3.
