Showroom 6DOF is a completely home-made platform in Latvia
Discussion in 'DIY Motion Simulator Projects' started by Ivan Zaharov, Mar 23, 2020.
  1. Ivan Zaharov
    Ivan Zaharov Member Gold Contributor
    Industrial repair CNC
    Latvija
    219Coins
    2DOF, AC motor, Arduino, Motion platform, 6DOF
  2. Ivan Zaharov
    Latvija
    219Coins
    Hello. Made a platform. I haven’t started yet. I make an electric automation cabinet with drivers. If anyone has any comments, write, do not be shy. Since I am new to this business, any comments are also useful information for me.
  3. SeatTime
    Full steel actuators... they won't break in a hurry :). Old tech, but still a very nicely built Stewart Platform :thumbs. Look forward to seeing it in action.
  4. Ivan Zaharov
    Latvija
    219Coins
    Hello. He made a cabinet with drivers, which still needs to be supplemented.
    • Winner Winner x 3
  5. Ivan Zaharov
    Latvija
    219Coins
    Thanks for the answer. Do not break !!! Everything is done with a large margin of safety. The following I want to make completely stainless steel.
  6. Ivan Zaharov
    Latvija
    219Coins
    Hello. Good start. So far with a stroke limit of 150mm. We need to work on the settings.
  7. Ivan Zaharov
    Latvija
    219Coins
    Tell me please. Reinstalled Windows 10 Home, there was a problem. AASD15 does not communicate with the computer, while the COM port is active. The driver is installed correctly. The plugin is loaded into SimTools. In SimTools, the settings are correct. What is the problem? Help!
  8. Gadget999
    12,053Coins
    try closing and reopening simtools
    does it work if you reboot computer ?
  9. Ivan Zaharov
    Latvija
    219Coins
    Thanks. Rebooted, still does not work.
  10. SeatTime
    Did it work before you re-installed Windows 10 ? Maybe you are now missing some required files?
  11. Ivan Zaharov
    Latvija
    219Coins
    Hello/ Previously, Windows 10LTSC was installed, everything worked. on 10Home stopped. SimTools reinstalled, did not help.
  12. SeatTime
    Well if it worked before, your obviously now missing something, maybe Net files which Simtools requires to work.
  13. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    Is .NET installed.
    Have you tried temporarily disabling any anti-virus and firewall, then do a clean install of SimTools.
  14. Ivan Zaharov
    Latvija
    219Coins
  15. Ivan Zaharov
    Latvija
    219Coins
    AMC-Thanos . Controller ok.
  16. Ivan Zaharov
    Latvija
    219Coins
    Disabled Windows and Anti-Virus protection. Then reinstalled SimTools. Does not work.
  17. SeatTime
    Sorry, I don't have any other ideas, although obviously something has changed from your last installation of Windows to this. Good luck :thumbs.
  18. noorbeast
    152,676Coins
    +11,089 / 56 / -2
