Double 2DOF seat-mover based on true rally car body
Discussion in 'DIY Motion Simulator Projects' started by nicopoche, Jan 24, 2020.
  1. nicopoche
    nicopoche Member
    Musician
    259Coins
    Hello !
    Here is my new project ( or my dad project because my project is here : https://www.xsimulator.net/community/threads/3dof-with-350w-dc-motors-nicopoche.11699/ )
    I raced for years on a 106 F2000 and now we try to "reproduce" it in simulator ^^
    We want that the 2 seats move at the same time in 2Dof with only 2 motors and here is the solution we found :
    And now we are here :
    New pics are coming because now the car is painted, and we are close to make the first tests :)
  2. nicopoche
    nicopoche Member
    Musician
    259Coins
    Here is the first test we made "unmounted" :
    [flash width=425 height=350 loop=false flashvars=]
    And the car I used to drive in real :) :
    The engine is now a computer ^^ : ( don't worry, we didn't cut my rally car... We sold it et bought a crashed 106 rally body to make this simulator ^^ )
    153,830Coins
    +11,151 / 57 / -2
    Have the motors been tested with a 2 person load?
    Design wise the uni joint should be as close to the seat as possible, in particular with a compact design that has limited inherent design leverage.
  4. nicopoche
    nicopoche Member
    Musician
    259Coins
    Thanks for your reply and tips :)
    You are right, the joints have been modified since the picture, thez are now closer to the seat. We have not tested yet with 2 persons, but the levers are very short so we are confident ( or too optimistic :D )
    At the biginning of the project, we thougt about moving all the car body :grin:grin:grin:grin
  5. RacingMat
    21,082Coins
    Excellent idea! and nice beginning :popcorn
    maybe you could edit the thread title into something like "Double 2DOF seat-mover with
    true rally car body" because it's really special. We don't often see double simulators.
    Hope you will upgrade the wheel...
  6. nicopoche
    nicopoche Member
    Musician
    259Coins
    Thank you Racing Mat...
    I think we will update the wheel in the future, we know that the T300 will be weak.
    I 'd like to change the title of this thread, but can't find how to do that... I'm just able to edit what is inside the thread...
    I will work on the sim this week-end, i will make more pictures beacause my dad works very fast on it and never takes pictures :D
    The car is painted, we are very close to the first tests !!!
  7. RacingMat
    21,082Coins
  8. nicopoche
    nicopoche Member
    Musician
    259Coins
    Thank you ! Title changed ^^
    I'm just working on it... Having a headache with something I thought that it would be a detail. As you cas see on previous pictures, the T300 wheel is away from the T300 base. So I have to manage a long cable linking wheel and base, wrapping randomly around the wheel during turning right and left...
    Will find a solution :)
  9. RacingMat
    21,082Coins
    soooooooo truuuuuuuuuuuue!!! :confused:
    keep going!
  10. nicopoche
    nicopoche Member
    Musician
    259Coins
    Hello !!!
    Now we are here !
    First test with a TV. Next, we will make a screen and use a short throw projector.
  11. nicopoche
    nicopoche Member
    Musician
    259Coins
    For the wheel, I found the radical solution. :D
    I opened the wheel base, took off the cable that connects normally to the wheel and passed it at the rear of the base. So now, i can connect directly the wheel button part directly next to its base, and everything is fixed ( no cables turning with wheel ).
    The problem, when I'm in the car, the wheel button are now unaccessible ( outside the car )... Ok, so i soldered 2 cables on each contactor button of the T300 button part ( for the moment only on shift + / - and handbrake but I can do it on each button of the T300 ) and go to the in-car contactors on my handbrake and shifter.
    With the other buttons of the T300, i will be able to make a little button box in the car...
  12. RacingMat
    21,082Coins
    :grin
    This guy could be interested in using your cockpit!!
  13. nicopoche
    nicopoche Member
    Musician
    259Coins
    Hey ! :)
    First tests with the videoprojector !
    It's my dad driving, fasten your seatbelt :D
    Everything works very well !!!! Yeahhhhhhhhhh
    I will make more pitures and videos ;-)
    • Like Like x 5
  14. PairRoc
    PairRoc New Member
    China
    190Coins
    2DOF, SCN5, SimforceGT
    Some great progress you've made!Starting to look really good. Nice work on the car body indeed.
  15. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Haha realy nice clip, youre gonne have fun together. first thing I would change is a direct drive wheel. Thats going to take it to the next level! Nice build!
  16. nicopoche
    nicopoche Member
    Musician
    259Coins
    Thank you !
    Yes, we are now thinking about making a direct drive :)
    This project deserves it :)
  17. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Do you als use Richard Burns rally? Awesome sim.
  18. nicopoche
    nicopoche Member
    Musician
    259Coins
    Currently, there is only Dirt rally 2 installed on this PC.
    I played hundred of hours on RBR years ago, you are right, the best rally sim...!
    This motion simulator is mainly for my dad, and he is not a simracer ( not even a gamer :D ) so Dirt is already quite hard for him ^^
    I have my own 3Dof and play 100% Assetto Corsa Competizione ;-)
    Some photos I took today :
  19. nicopoche
    nicopoche Member
    Musician
    259Coins
    Hello !
    Some news for this project !
    The car is now in its final place.
    The game will be projected directly on the wall.
  20. nicopoche
    nicopoche Member
    Musician
    259Coins
    And today i'm finishing the wall with a special projection paint, and also finishing a 7 inch screen dashboard :)
    Pictures are coming soon !!!!
