F1 Motion Simulator // 5th monitor
Discussion in 'DIY Motion Simulator Projects' started by foppaul, Sep 28, 2017.
  1. foppaul
    foppaul Member
    Nederland
    198Coins
    Another update! More speakers haha
    Nicely finished the wiring:
    And a center speaker:
    Now I need to tidy up the wiring all around.
  2. foppaul
    foppaul Member
    Nederland
    198Coins
    I have a small issue with simtools. When I boot up the pc, simtools start automaticlly. That works fine. But it cant connect to the smc3 arduino. I have to unplug the arduino. Restart Simtools, get a no connection notification, reconnect the arduino and then it suddenly connects. Can anyone help me with this?
    p.s. Updates will follow soon
    150,950Coins
    +11,025 / 56 / -2
    Sounds like you have checked the Start With Windows box in the Tools menu of Game Manager. So if you don't want SimTools to start with Windows then uncheck that setting.
    You can use the Launcher to start SimTools and whatever companion apps you want at the same time: https://www.xsimulator.net/community/marketplace/simtools-v2-launcher.202/
  4. foppaul
    foppaul Member
    Nederland
    198Coins
    I want Simtools to start with Windows. But I think that Simhub takes the com port of the scm arduino when it is launched first. But I'll try the launcher, maybe that solves everything
    150,950Coins
    +11,025 / 56 / -2
    In that case change the ports being used.
  6. foppaul
    foppaul Member
    Nederland
    198Coins
    I think i've found the problem. I use simcommander for simvibe, Simtools for motion and the Codemasters f1 2017 game. And i've read that that doesn't work together. They use different type of extradata and Codemasters only sends out one. That why tools like CMPS don't work either. So that sucks haha. I hope that I'm wrong and that someone has some good advice...
    And the update:
    I've finished the steeringwheel!
    Then soldered a new circuit to convert the arduino PWM to an analog signal for the VFD's. This also fixed the rocking past the target point:
    And this is were we are right now:
    Just fixing some software issues and then I'll post a video!
    150,950Coins
    +11,025 / 56 / -2
  8. foppaul
    foppaul Member
    Nederland
    198Coins
    @noorbeast Simtools and SimCommander both seem to use port 20777. I can't change it in SimCommander, is it possible to change to port of the F!_2017 plugin?
    150,950Coins
    +11,025 / 56 / -2
  10. foppaul
    foppaul Member
    Nederland
    198Coins
    I tried that, but as long as they have the same UPD port there will be a conflict. Can't forward to two programs that use te same UDP port
    150,950Coins
    +11,025 / 56 / -2
  12. foppaul
    foppaul Member
    Nederland
    198Coins
    Didn't come across that one until now, i'll try it tomorrow! Thanks
  13. foppaul
    foppaul Member
    Nederland
    198Coins
    So, I can't add an extra UDP adress. Codemasters F1 only acceptes 1 output.. But I've found another F1 2017 plugin and that plugin uses port 5606. And that fixes the problem. I use simhub as an UDP relay and the output works great. Now I just need to fix some minor details.
  14. foppaul
    foppaul Member
    Nederland
    198Coins
    I've got F1 2017 working for a while now. Great fun. But I totally forgot to post a video. I will try to rember te make one.
  15. foppaul
    foppaul Member
    Nederland
    198Coins
    Also bought F1 2019. So an upgrade is coming..
  16. foppaul
    foppaul Member
    Nederland
    198Coins
    Long time no see...
    Good news, everything works perfect! I moved the simulator to a different room. About 6 hours of work haha
    Before:
    (Below)
    And after:
    (Below)
    Then I started using SimDash on a tablet, why u ask? I think it more fun to give the spectators an extra dimension when you are gaming with some friends. Below you see the most recent result. It's not perfect but I really dig the interactive communicaiton.
    (Something went wrong while uploading the photo's, I'dont know what but this seems to work...)
  17. foppaul
    foppaul Member
    Nederland
    198Coins
    Next step: Ambilight
    Ordered some ledstrips and a controller on Aliexpress :grin
    But unexpectedly it works great haha
    This is the ledstrip behind the monitor:
    And from behind:
    I am not sure if I should keep it or not I like it but I don't know if it improves the racing, but this is the result so far
  18. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
    Beautiful work!
    Im still using my first proto version and thinking what kind of frame is to the next version. This is good looking like piece of art.
  19. foppaul
    foppaul Member
    Nederland
    198Coins
    Another upgrade wich makes gaming more realistic and more fun. I've just added a secondairy and third monitor. One biggie for the driver and a smaller one for spectators.
  20. Gadget999
    11,971Coins
    looking good !
    how much movement do you have when the sim moves ? do the screens move about much ?
