Bug Jrk plugin. Dll
Discussion in 'SimTools DIY Version' started by morsilli, Mar 18, 2019.
  1. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    Bonjour du jours au lendemain j'ai eu une erreur au lancement de simtools : JRK_interfacePlugin. dll- is Not à valid interface Plugin !
    Depuis inmossible de faire fonctionner le simulateur au le cément du jeux. J'arrive à le faire fonctionner dans le game manager en l activant mais lorsque je lance un jeux le game engine disparaît.
    Pouvez vous m'aider ? Merci
  2. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    ok so i've just finished to reinstal simtools, and now when i launch a game, game engine stop , it shut down when the game is launching...
    when i test manually in game engin in output testing, it works.
    i run windows 10 64bits.
    i think simtools crash since i've installed windows update but i don't know what i have to do now?
    What is the problem?
    thanks for help. ( and sorry for my english :) )
    153,866Coins
    +11,152 / 57 / -2
  4. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    ok no problem!
    i see game manager is "game running" when i start the game. But game engine stop...
    153,866Coins
    +11,152 / 57 / -2
    Did you re-register SimTools: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    Are there any error messages, if so please post a picture of them
    Is the computer set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  6. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    simtools is still registred, "diy valid licence found " when i launch it.
    . i tried to re register now to test but i have no activation remaning on this licence. (but why it works yesterday and today i have this issu? )
    I have no error message like "JRK_interfacePlugin. dll- is Not à valid interface Plugin !" since I re installed simtools earlier but I still have the game engine cut at when the game is launching.
    i can't post any picture beacause there is no error messages...
  7. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    i've juste tried to set english local but i still have the same issu.
    i send request to simtools support to reset my licence.
    I have the impression that it's since there was a windows update that I have the problem ...
  8. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
  9. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    in Windows event viewer i have this report:
    Nom de l’application défaillante SimTools_GameEngine.exe, version : 0.2.3.1, horodatage : 0x5c1445f5
    Nom du module défaillant : KERNELBASE.dll, version : 10.0.17134.556, horodatage : 0xadca2670
    Code d’exception : 0xe0434352
    Décalage d’erreur : 0x001118a2
    ID du processus défaillant : 0x30d4
    Heure de début de l’application défaillante : 0x01d4de3d32afb2d9
    Chemin d’accès de l’application défaillante : C:\Program Files (x86)\SimTools\SimTools_GameEngine.exe
    Chemin d’accès du module défaillant: C:\Windows\System32\KERNELBASE.dll
    ID de rapport : 788816e3-0771-4e63-a2ed-64dc8536ebe4
    Nom complet du package défaillant :
    ID de l’application relative au package défaillant :
  10. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    i find the problème.
    thanks to yobuddy , i had to:
    goto:
    C:\Users\(your user folder)\AppData\Local\SimTools\GameManager\GameProfiles
    Here you will have 2 folders 'LastUsed' and 'Profiles'.
    In 'LastUsed' delete the file for "the game".
    In 'Profiles' delete the "game" folder.
    Restart SimTools and it will works.
  11. yobuddy
    51,535Coins
    The next version of SimTools will not only avoid these kind of problems, but will also fix them as needed.
    Take care!
