Showroom Playseat Challenge - Maximum modifications (G-seat, Windsim, Handbrake, Brake/Throttle feedback)
Discussion in 'DIY Motion Simulator Projects' started by MCage, Feb 27, 2019.
  1. MCage
    MCage New Member
    Nederland
    43Coins
    Hi there,
    I'm a longtime reader of this forum and used this forum for lot of reasearch and ideas.
    Over the past year or so I had to make a choice on a racing rig. Nr 1 on the list was portability and ease of setup.
    Therefore I finaly settled for a ready made chair but to add all my required addons in stages while maintaining portability. For this I chose the Playseat Challange: relatively cheap, good build quality, lots of room to add stuff to it and fully collapsible with everything attached in under a minute.
    Now besides the bare chair I wanted to add the following besides my Logitech G27 with shifter set:
    For the feedback in the chair itself I opted for the Gametrix jetseat
    Everything except G-seat is now in place. The G-seat portion is in the works and all parts are ordered and slowly getting in.. so thought would be time to write up on the how to's..
    For the software I use the following:
    For the G-seat I'm planning to use SimTools
    NB. Since I own a 3D printer, quite a lot of 3D printing has been done to create the end result. Concidering the low prices of 3D printers these days esp compared to the stuff we might add to our rigs its a nice investment that may pay off..
  2. MCage
    MCage New Member
    Nederland
    43Coins
    Part 1: Handbrake for G27
    20171029_151654 - kopie.jpg 20171029_115017 - kopie.jpg 20171029_122538 - kopie.jpg
    3D printer files:
    Electronic/components:
    Instructions
    • Print the 3D files (used PLA, 0.3mm layer height, heigh infill)
    • Add the roller switches and connect them to the 3.5mm male jack connector (see pic for wirediagram)
    • Use the following manual:
      for soldering the connections to the G27 shifter module and instead of a fixed output lead I used the 3.5mm female connector on the side (see first pic on location)
  3. MCage
    MCage New Member
    Nederland
    43Coins
    Part 2: Suspension feedback (buttkickers)
    3D printer files:
    • 2x Transducer
    • 1x amp
    • 2x RCA female connector
    • Speaker cable
    Software/code
    Instructions:
    • Connect a piece of wood to the front and back using the 3D printed connectors as shown in pictures
    • Add the mounting plate to the wood using wood screws
    • Add the transducer as shown to the mounting plate.
    • Solder the speaker cable to the transducer and RCA connectors
    • !! Make sure to watch out for the impedence of the transducters.. Mine got really hot on load and had to run them in parallel instead each channel seperate to reduce heat.
  4. MCage
    MCage New Member
    Nederland
    43Coins
    Part 3: Wind Sim
    20181210_111117.jpg 20181210_111122.jpg 20181210_111127.jpg 20190324_113013 - kopie.jpg
    3D printer files:
    Alternative GoPro mount (not tested myself)
    Software/code:
    Instructions:
    • Print the 3D files (PLA, 0.2mm, 20% infill)
    • For the code and wiring, follow these (https://github.com/kshiba/SimHUB-WindSim-Scketch) instructions
    • The control box where the arduino houses is fixed using double sided tape
    • All USB wiring go to one central USB hub at the bottom front of the chair
    • In SimHub simply add the arduino, call it 'WINDSIM' and set the message binding according to the instructions here
  5. MCage
    MCage New Member
    Nederland
    43Coins
  6. MCage
    MCage New Member
    Nederland
    43Coins
    Part 5: Pneumatic G-seat
    3D printer files:
    Software/code:
    Instructions:
    So this took a bit longer then expected due to getting all the parts in (especially the Chinese ones).
    In the mean time I started designing and printing the electronics housing part and thinking about the placement of all the components on the Playseat Challange.
    For the placement of the servo's and bladders I got to think to place them on the back side of the chair where I have currently one basshaker. To get some more room I will move the crossbar on top instead now below the leggs and add another crossbar to mount the hinges tight. I already printed the connectors and got the crossbar on length and painted.
    For the electronics housing I opted for one case with the PSU, DC converter and Arduino integrated. I came up with this:
    Basicly its 3 cases created with The Unlimited Box Maker glued together ;)
    Now I'm fairly new to all the arduino electronics stuff and just uploaded some code, hooked the servo and... got some weird effects on the servo like jitter.. Now I found a lot of posts on Arduino and servo jitter but no solution initially. Example of my servo jitter
    Till I just found the solution: common ground.. as the servo is powered by my PSU and the Arduino gets the power by the USB port the ground level differs from the pin it gets driven by. Making a common ground between the PSU, Arduino and Servo fixed the annoying jitter issue.
    Now that sorted I just have to get the simtools software to start testing the connections and arduino code.
    While waiting for the license I started adding the mounting support on the seat to accomodate the bladder bags. Make sure to use some isolation tape to the mounting parts to avoid scratches and to improve friction
    Mounting the extra cross bar:
    Support bar installed:
    Now ready to add the hinges and bladder bags.
    All 4 bags installed. 2 on each side!
    I used some velcro to mount the bags to the hinges
    20190325_142024 - kopie.jpg 20190325_142201 - kopie.jpg 20190325_142928 - kopie.jpg
    Now its time to add the 4 bladders that will provide the lifting
    I installed 2 at the back side and 2 at the seat. For now I placed them loose to test the placement but in the end I will secure them with some velcro
    Now it is time for some plumbing ;) Each lifting bag is coupled to a T connector which goes to both the bladder at the servo side and to the pump/valve used to control the initial air pressure
    20190325_144549 - kopie.jpg 20190325_144556 - kopie.jpg 20190325_145542 - kopie.jpg 20190325_150846 - kopie.jpg
    With all the plumbing in place, the next step is the electronics. I start with the Servo's.
    Note that I found that you have to pay close attention to the turn orientation of the Servo in regards to the axis of the Servo. The axis placement is not in the center so when you place it the wrong way around the arm can get stuck to the hinge!
    NB. As you can see, I mounted the servo's with common tie wraps. To secure them more firmly and restrict vertical movement I taped them as well in the end.
    With all the servo's in place, it's time for the elecrical wiring. First I wanted to use all the connectors for ease of maintenance. I soon found it would be too fragile so I soldered everything together. Tie wrapped everything to the cross bars and guided the wiring to the front at the x-joint of the chair itself.
    Well, spoiler. As you could tell from the last fotograph to illustrate the wiring it was now time to place the electronics box.
    I mounted the electronicsbox simply by using screws and screwing it through the bottom of the box to the crossbar at the front. Now, I got a bit of a challenge with my box design with the arduino connection I didn't account for. The USB connector is way too long, so I cut a hole to the side so the USB connector would fit.
    Hook up all the connectors as by my initial test using the common ground and close the case. I secured it with tape the hinges proved to fragile with PLA.
    All the hardware is now in place, now on to the software. I used the following settings (can't recall the source to reference but sure didn't find out myself ;))
    Here are the Interface output settings:
    R<Axis1b>~L<Axis2b>~F<Axis3b>~B<Axis4b>~G<Axis5b>~H<Axis6b>~
    These are my settings in game:
    And that sums up my little project. It was a fun ride and I must say, it adds far more immersion then I anticipated. Especially the heave is an extra bonus I didn't account for. Hope someone can have some advantage with their build with this, have fun..
    Log:
    - 30/3 Final tweaks and finish up of the project
    - 27/3 Simtools setup and first testing
    - 26/3 Installed all wiring
    - 25/3 Installed all hardware components and pneumatics
    - 24/3 All ordered components in
    - 4/3 Started designing and printing parts
    - 28/2 Ordered all the parts and some are already getting in. Added the list of parts ordered and the shops
    • case.rar
      1.1 MB
      1,195
  7. MCage
    MCage New Member
    Nederland
    43Coins
    Well, that's a wrap! Latest addition G-seat done and working!
    Probably most people didn't even notice my threat as I just eddited my posts instead of adding posts so it got swamped down. But to raise some more awareness: It's done and works (most importantly, still foldable and portable!)
    Enjoy and till the next project (or if you have some questions feel free to ask)
  8. asteroulis
    asteroulis New Member
    174Coins
    DC motor
    Well this is a great project . I Just received a playseat challenge because I was curious for my children , and I immediately started searching for upgrading possibilities because it's soooo well made. I was thinking about bass shakers , but I was really amazed by your pneumatic project there!
  9. MCage
    MCage New Member
    Nederland
    43Coins
    Thnx, stil working great even after all that time.
    Changed the gseat from 2 at back and 2 at legs to all 4 at the back: 2 at the sides for left and right turns and 2 in the center of back for surge (brake and accelerate) for better immersion.
  10. RacingMat
    21,068Coins
    congrats!! very good job and neat improvements :thumbs
    that would be so cool to see a video of the pneumatic Gseat
  11. MCage
    MCage New Member
    Nederland
    43Coins
    Will try soon.. bit tricky to drive and record the same time. Will setup some axis and effect simulation and record it.
  12. Jumping Coin
    Jumping Coin Member
    82Coins
    Excellent write-up @MCage ! I'm hoping to do a similar G-Seat project. My only problem is I can't seem to find those types hinges. All of the hinges that I find are long rather than wide. Any suggestions for where to pick them up or what search terms to use to find them?
    Thanks!
