Showroom Building my first 2DOF (without welding or a steel frame)
Discussion in 'DIY Motion Simulator Projects' started by Brie69, Jul 3, 2018.
  1. noorbeast
    153,920Coins
    +11,156 / 57 / -2
    For motors that can be back driven when not powered on members often use fold in chocks to block the motor.
    The other option is to power the rig on, but do make sure it is well balanced. The Joystick plugin can be used for games that do not have a dedicated motion plugin: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
  2. Brie69
    Brie69 Active Member
    Beverwijk
    2Coins
    Thanks for answering that question @noorbeast ;)
  3. KONIU
    KONIU Member
    Poland
    449Coins
    Noorbeast thx for answer. Rig also I using for internet surfing etc. So acc. to yours info, for me the best solution is using chocks or bars for pernamently and solid block motors or seat when no motion (no neccesary keep power on motors). This is no the best solution but why I can do. Again thx.
  4. Brie69
    Beverwijk
    2Coins
    Putting some safty switches in there.
  5. Brie69
    Beverwijk
    2Coins
    Working on the sim again...
  6. Brie69
    Beverwijk
    2Coins
  7. Brie69
    Beverwijk
    2Coins
  8. Brie69
    Beverwijk
    2Coins
    IMG_20190531_103132431.jpg Ones you go black you never go back
  9. Brie69
    Beverwijk
    2Coins
  10. Brie69
    Beverwijk
    2Coins
    Layer numbero uno!
  11. Brie69
    Beverwijk
    2Coins
    Caution the Last Layer of Wet Paint (for now)
  12. Brie69
    Beverwijk
    2Coins
    Maybe handy for others
    In this way the PVC pipe stays exactly in the middle
  13. Brie69
    Beverwijk
    2Coins
    The puzzle pieces come together.
    Next week I will do the cabling, emergency stop, start key, bass shakers and more ...
  14. robotics0
    robotics0 New Member
    87Coins
    Motion platform
    This informative thread put a lot of thoughts into perspective, good project:thumbs
  15. Brie69
    Beverwijk
    2Coins
  16. Brie69
    Beverwijk
    2Coins
    I have now noticed that these arms make a noise due to the small play between the M10 thread and the rod head when moving.
    To solve this problem, you need approximately 2.3 cm of insulation tape. Cut the tape neatly with scissors and do not pull it off the roll. Otherwise the tape will shrink again.
    Stick the tape around the thread end. Make sure that the end and the beginning of the tape do not overlap.
    Now place the rod head on the M10 thread with a circular motion and light pressure. Do this carefully so that the tape does not curl.
    Where the red arrows are on the photo was first the play which is now replaced by insulating tape
    If you now pull the rod head, in the direction that the engines will do, then the annoying 'click sound' has now completely disappeared.
    ps. Do this of course with every rod end
    Hopefully I could help someone.
  17. Brie69
    Beverwijk
    2Coins
    I found the base a little too high, so I did some sawing work
  18. Brie69
    Beverwijk
    2Coins
    I am currently working on making a small digital dashboard
    1a.jpg IMG_20190914_095430212.jpg IMG_20190914_095455526.jpg IMG_20190914_095516570.jpg IMG_20190914_100429962.jpg IMG_20190914_104125051.jpg IMG_20190914_110903107.jpg IMG_20190915_200332958.jpg IMG_20190915_200609589.jpg
    Waiting for the paint to dry....
  19. Brie69
    Beverwijk
    2Coins
    Unfortunately, the angle of the screen was not good enough.
  20. Brie69
    Beverwijk
    2Coins
    S C R A P
