Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. pmvcda
    15,702Coins
    It doesn't solve the 127 limit in the output.
    My settings for output are:
    And with a simple c# code to retrieve the bytes from the string:
    If value at maximum (sway):
    Medium:
    Minimum:
    When simtools writes the binary output to a string, it's using basic ASCII, only 7 bits, so we only get values up to 127.
    We need extended ASCII.
    I might be completely wrong...
  2. yobuddy
    51,547Coins
    Did you reboot after the change?
    This usually shows up only when a coma is used as a decimal point.
    I can take a look when I get up tomorrow.
    Take care,
  3. pmvcda
    15,702Coins
    Yes I reboot.
    Thank's for taking a look.
    Good sleep :cool:
  4. pmvcda
    15,702Coins
  5. yobuddy
    51,547Coins
    @pmvcda,
    Sorry for the delay, not feeling to hot over the weekend.
    But I will have an answer tomorrow buddy.
  6. yobuddy
    51,547Coins
    @pmvcda,
    Please drop this into the SimTools Plugin Updater and give it a try.
    Let me know how it goes buddy!
  7. pmvcda
    15,702Coins
    I tried, but now with 16 bit and binary, I get from 2 to 4 bytes for the value.
    83 and 126 are the start of info.
    58 and 127 separators.
    You can see bellow, that we get up to 4 bytes:
  8. pmvcda
    15,702Coins
    OK,
    @yobuddy, I solved the problem.
    I didn't noticed that this was a plugin. :oops:
    So I modified the code to send UShort values and now it's working, but only for binary and 16 bits:
    The changed code for the plugin:
    Code:
        'My Output data Structure
        Private MyMMFData As New MMFData
        Private Structure MMFData
            Public _Axis1a As UShort
            Public _Axis2a As UShort
            Public _Axis3a As UShort
            Public _Axis4a As UShort
            Public _Axis5a As UShort
            Public _Axis6a As UShort
            Public _Axis1b As UShort
            Public _Axis2b As UShort
            Public _Axis3b As UShort
            Public _Axis4b As UShort
            Public _Axis5b As UShort
            Public _Axis6b As UShort
        End Structure
        'write MMF to memory
        Private Sub SendMMF(MyData As MMFData)
            Dim accessor As System.IO.MemoryMappedFiles.MemoryMappedViewAccessor = Interface_MMF.CreateViewAccessor()
            accessor.Write(0, MyMMFData._Axis1a)
            accessor.Write(2, MyMMFData._Axis2a)
            accessor.Write(4, MyMMFData._Axis3a)
            accessor.Write(6, MyMMFData._Axis4a)
            accessor.Write(8, MyMMFData._Axis5a)
            accessor.Write(10, MyMMFData._Axis6a)
            accessor.Write(12, MyMMFData._Axis1b)
            accessor.Write(14, MyMMFData._Axis2b)
            accessor.Write(16, MyMMFData._Axis3b)
            accessor.Write(18, MyMMFData._Axis4b)
            accessor.Write(20, MyMMFData._Axis5b)
            accessor.Write(22, MyMMFData._Axis6b)
            accessor.Dispose()
        End Sub
        'Returns the final output scaled to BitsNeeded and with Type
        Private Function GetOutPut(ByVal InputPercent As Double, ByVal BitsNeeded As String, ByVal Type As String) As UShort
            Dim OutPut As UShort = 0
            'ONLY FOR 16 BITS AND BINARY
            If InputPercent >= 0 Then
                OutPut = CUShort((InputPercent * 32768) + 32767)
            Else
                OutPut = CUShort(32767 - (InputPercent * -32767))
            End If
            Return OutPut
        End Function
    And the dll to test for download
  9. yobuddy
    51,547Coins
    You can't simply parse the string by commas as binary also puts out a comma.
    But with binary you can grab the values by location in the string as it does not change.
    So there was not anything to fix is all I'm saying.
    Take care,
  10. pmvcda
    15,702Coins
    In the plugin you are using ASCII encoding.
    From Microsoft @ https://docs.microsoft.com/en-us/dotnet/api/system.text.asciiencoding?view=netframework-4.7.2
    With the serial interface and binary output, I have no problems.
    The sample code for memory mapped file:
    Code:
            Dim Buffer As Byte() = System.Text.ASCIIEncoding.ASCII.GetBytes(MyMMFData._Axis1a & "," & MyMMFData._Axis2a & "," & MyMMFData._Axis3a & "," & MyMMFData._Axis4a & "," & MyMMFData._Axis5a & "," & MyMMFData._Axis6a & "," & MyMMFData._Axis1b & "," & MyMMFData._Axis2b & "," & MyMMFData._Axis3b & "," & MyMMFData._Axis4b & "," & MyMMFData._Axis5b & "," & MyMMFData._Axis6b & ",")
            accessor.Write(0, CUShort(Buffer.Length))
            accessor.WriteArray(0, Buffer, 0, Buffer.Length)
            accessor.Dispose()
        End Sub
    Replaced with:
    Code:
            Dim x As String = MyMMFData._Axis1a & "," & MyMMFData._Axis2a & "," & MyMMFData._Axis3a & "," & MyMMFData._Axis4a & "," & MyMMFData._Axis5a & "," & MyMMFData._Axis6a & "," & MyMMFData._Axis1b & "," & MyMMFData._Axis2b & "," & MyMMFData._Axis3b & "," & MyMMFData._Axis4b & "," & MyMMFData._Axis5b & "," & MyMMFData._Axis6b & ","
            For n As Int32 = 0 To x.Length - 1
                accessor.Write(n, CByte(Asc(x(n))))
            Next
            accessor.Dispose()
        End Sub
    works.
  11. yobuddy
    51,547Coins
  12. yobuddy
    51,547Coins
    I see now that you may have the old source code for the plugin.
    I think that is where the confusion is coming from buddy.
    And reminds me I'll need to update the source on the plugin as there is other fixes in the plugin I did a wile back.
    Also, it looks like having configurable output may be the way to go here.
    (Much like the serial or net Interface - Output line.)
    Then you can pattern the output to look exactly as one would like.
  13. yobuddy
    51,547Coins
  14. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    I had this problem of internet connection yesterday with registration because I changed my SSD that I cloned, I had version 2.3 and I had to re-register my license. I downloaded version 2.3.1 and it worked perfectly.
    Thank you for your work.
    Ps: a pity for me, because before that I tried to reinstall simtools and I lost all my settings ...
    153,950Coins
    +11,159 / 57 / -2
    Just
    Just for future reference say No to overwrite existing settings. Or here is an alternative approach: https://www.xsimulator.net/community/faq/how-to-keep-my-settings-in-case-of-a-plugin-update.11/
  16. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    of course, that's what I did at first but as nothing worked because I reinstalled the version 2.3, I finally uninstall everything and delete all the files related to simtools and then I reinstalled everything again and there , always nothing.
    that's when I decided to search the internet and found that version 2.3.1 fixed this problem.
    it's not a big deal, today I should finish putting all my settings right. ;-)
  17. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    going to update, just a few questions
    will it automatically see that i already have a licence key installed ?
    -if not where do i find it to write it down?
    after deleting all old settings do i have to set up again from scratch ?
    i have to re-do the game plug in ?
    big thanks in advance
  18. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    If you are just updating SimTools 2 to the latest version then say No to overwrite existing settings. Just to be safe here is how to first make a backup: https://www.xsimulator.net/community/faq/how-to-keep-my-settings-in-case-of-a-plugin-update.11/
    If you are updating from SimTools 1.3 to SimTools 2 then you will need to redo your settings.
  19. yobuddy
    51,547Coins
    Yes
    Not if you install over the top of the old version.
    (in most cases anyway) To update a SCN sim from SimTools v2.2 and before, simply remove your interfaces first.
    Install the update and re-setup your interfaces.
    Take care,
  20. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    My Simtools was installed a couple of years ago so it must be an old version
    I’ll try re-fresh my memory & re-do from scratch
    Big thanks for the help all
