| 2DOF Seatmover | 2 x Transducers |...
Discussion in 'DIY Motion Simulator Projects' started by CQeNS, Oct 4, 2018.
  1. CQeNS
    CQeNS New Member
    50Coins
    Just wanted to share my build for any anyone who is thinking of building their own seat mover. This was such an awesome project! I have not completed anything of this magnitude before, but I learn a lot along the way! This forum is a deep well of information but sorting through can be a bit difficult, especially with some builds and information that is a bit outdated. Many thanks to the active members on this forum that provide constant support!
    For this first phase, I tried to keep welding to a minimum and used 2x4s for most of the construction. The plan is to keep things flexible for future experimentation, expansion, and keep initial R&D costs down )
    General rig build info:
    PGSaw 25:1 180w motors
    HP ProLiant DL380 575W power-supplies
    BOURNS 6639S potentiometers
    JRK 18v19 motor controllers
    Transducer setup:
    2 x Auras 50W
    MEAN WELL LRS-200-24 powersupply
    Sure Electronics AA-AB32971 2x100W Amplifier
    2 x USB sound cards
    Product of all the sufferings)
  2. CQeNS
    CQeNS New Member
    50Coins
    We all got to start somewhere )
    I really like my driving potion, so I tried my best to recreate all of the measurements, pedal, seat, steering wheel height.
    I went with a 2 x of Flange Yoke as suggested by someone on this forum. Putting U joint together was not as easy I thought it would be, using proper tools would have made this part of the project much easier. I don't own a welder but have access to one, so for the initial version of this project I decided to bolt things together and get it working first. The threaded rod helped a lot with front to back flex in the brackets.
  3. CQeNS
    CQeNS New Member
    50Coins
    I used a project box to house the JRKs mounted on Nylon spacers, and ran dual 60mm fans to move the air over the JRKs. I also soldered the wires directly to the boards as terminal blocks are only rated for 16 A.
    I soldered all the necessary pins together rather then running multiple connectors
  4. CQeNS
    CQeNS New Member
    50Coins
    This bracket was perfect thickness and spacing was a hair over ~55mm, exactly what I was looking for
    I was able to pinch the gearboxes on this 2x4 on both sides, this setup seems to hold up to the abuse so far. I went with QA1 Precision Products NFR8 rod ends, and used wheel nuts instead of conical spacers.
  5. CQeNS
    CQeNS New Member
    50Coins
    I decided to go down the wrap route.
    Was lucky to find this suede like material for the "dash") Came out really nice.
    Built a little enclosure for all of the electronics in the back
  6. CQeNS
    CQeNS New Member
    50Coins
    I spent a few hours on the simulator before tucking all the wires away, and decided to expend this first part of the build and go for the bass shakers setup. I felt like I was close to what I wanted out of the setup, but something was missing, and for me it ended up being the missing bit.
    I mounted one in the lower back area, and the second one right underneath the pedals
    All of the business in the back ) I already have the 3rd JRK motor, TL is somewhere in the future, but at the moment this will do!
    • Like Like x 7
  7. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,407Coins
    Hi, Great build by the way. I am looking at adding more transducers to my RIG. I have a single buttkicker gamer mounted to the back of my motion platform now, but wanted an opinion on the 2 x Auras 50W
    and your Sure Electronics AA-AB32971 2x100W Amplifier. My question is - if you mounted those Auras in the front of your rig (that's what I am planning to do btw) would they have enough power to simulate curbs etc..
    If you have a chance, take a look at my rig.. here https://www.xsimulator.net/community/threads/full-frame-2-dof-traction-loss-new-build.14740/
    Thanks! D
