Tutorial Arduino code for 4DOF and 1 DIRpin Hbridge board
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 7, 2013.
  1. alejandroads
    alejandroads New Member
    Unated States
    106Coins
    DC motor, Arduino
    Hello ! I start to build my motion simulator, I did all I'll found in this page, but now I'm stuck. When I go to simtools , output testing and them I press
    ''Turn on'' the motor move but when I tried to move the knobs after select axis output I moved and nothing happens ...Arduino board receive data and motor move when I turn on axis testing. ( moves ands stop)
    I'm using this code : Arduino Code for 4 DOF and 1 pins Hbridge boards.
    The only thing maybe could be wrong is I'm not connecting yet all motors, just one, and I connected 3 potenciometers to Arduino, one is installed in the motor , and the other two I moved manually for test, I pretend to used 2 motors and 1 extra motor for wind...
  2. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    RacingMat
    Please can you tell me if this scheme is right for me to use 2 arduino uno and 4 ibt2 to make a 4dof flight simulator using your 2dof code?
  3. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    Or would the correct schematic be this?
  4. phonghornet
    phonghornet New Member
    190Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    Hi Mat.
    compile error message.
    I do not know where I'm wrong.
  5. RacingMat
    21,028Coins
    Hi
    What did you change in the code ?
  6. phonghornet
    190Coins
    Hi Mat
    I found the error thank you.
    The directory that I save contains special characters, so I can not compile it.
  7. RacingMat
    21,028Coins
    Thanks for the feedback!
    Keep going and good luck :)
  8. phonghornet
    190Coins
    Hi Mat.Thank you.
    I am wanting to build an arduino + simtool + stepper motor.
  9. RacingMat
    21,028Coins
    Sorry, but I would advise you to stick to a known recipe ! Trying to innovate while being new to arduino will be hard and costly to my opinion ;-)
    Yours
  10. phonghornet
    190Coins
    I understand. Thank you
  11. RacingMat
    21,028Coins
    Thanks for your feedback :)
    And congratulations for your success!
  12. Joeri
    Joeri Member
    car body repair shop
    The Netherlands
    106Coins
    can i use 4 ibt2 whit this code?
    if so does anyone have a connection diagram?
    want to try to make a 4 dof, when my first project is finished :)
  13. Joeri
    Joeri Member
    The Netherlands
    106Coins
    150,968Coins
    +11,025 / 56 / -2
  15. Joeri
    Joeri Member
    The Netherlands
    106Coins
    I now use the smc3 code for my first project. but I want to control 4 motors. for my next project. I was wondering if that is possible with 4 ibt2?
  16. noorbeast
    150,968Coins
    +11,025 / 56 / -2
    Use 2 Arduinos and SMC3.
  17. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    136Coins
    2DOF, DC motor, SimforceGT
  18. noorbeast
    150,968Coins
    +11,025 / 56 / -2
    See my previous comment where I consider the easiest way to drive 4 motors is 2 Arduinos, each driving 2 motors using SMC3, as that way you have all the benefit of the SMC3 utility for configuration: https://www.xsimulator.net/communit...-dirpin-hbridge-board.4614/page-6#post-176494
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    136Coins
  20. NigaMan
    NigaMan New Member
    - 21Coins
    Hello everyone, so I wonder if it is possible to make 4dof according to one of the schemes?
