help endless potentiometers
Discussion in 'Electronic and hardware generally' started by francabrera, Jul 19, 2018.
  1. francabrera
    francabrera New Member
    córdoba
    271Coins
    hello, I want to install pots of more than 10 laps and I can not find endless pots, someone knows what kind of pots I can install that does not have buffers
    hola, quiero instalar pots de mas de 10 vueltas y no encuentro pots sin fin, alguien sabe que tipo de pots puedo instalar que no tenga topes
  2. SeatTime
    You want a rotary encoder.
  3. francabrera
    córdoba
    271Coins
    Which one would you recommend?
  4. SeatTime
    It Depends on what you are trying to do, plenty of info already on this site.
  5. francabrera
    córdoba
    271Coins
    I use these potentiometers for 10 laps but they break and that's why I'm looking for endless pots
  6. francabrera
    córdoba
    271Coins
  7. francabrera
    córdoba
    271Coins
    the axis has 180 degrees, and the potentiometers 10 turns, but sometimes I have connection problems and goes over the top and breaks them, I could make a gear but if there is no end I wanted to try
  8. francabrera
    córdoba
    271Coins
  9. SeatTime
    Oh, OK - your making this more complex then it needs to be for that application.. Just run a shaft off your current motor arms and just use continuous turn Hall sensor. See https://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/ for a bit more help.
  10. sam poole
    sam poole Active Member
    midlands
    66Coins
    Maybe try something like this it works perfectly for me
