Dirt Rally not patching
Discussion in 'SimTools Plugins' started by tomquid, May 5, 2018.
  1. tomquid
    tomquid New Member Gold Contributor
    NY
    133Coins
    I have trouble getting dirt rally to patch. I am new to simtools, but I am able to patch and run both AC and iracing with no issues.
    I have tried the other suggestions posted in the forums with no luck.
    It seems I need to run the game once before patching - I have ran it for days:)
    Running Win10 64, simtools 2.2 and Dirt Rally plugin 2.1.1.0 (I have also tried 2.0.0.3 but it crash).
    any suggestions would be appreciated.
    thanks
    152,553Coins
    +11,087 / 56 / -2
  3. tomquid
    NY
    133Coins
    Yes. I removed/delete them all from that location with no luck.
    I did forget to mention I run dirt from steam and are using oculus vr.
    Any ideas?
    152,553Coins
    +11,087 / 56 / -2
    If 2.0.0.3 crashes and 2.1.1.0 does not patch then it could be an issue with the game itself, try verifying the file integrity in Steam.
  5. tomquid
    NY
    133Coins
    everything verifies. should I try to re-install (the one thing I have not yet tried), or do you think it could be something else?
    thanks
    152,553Coins
    +11,087 / 56 / -2
    Have you used elevated admin permissions at any stage?
  7. tomquid
    NY
    133Coins
    Not for steam or simtools. I run simvibe as an admin but have been trying to patch and run the game from steam.
  8. tomquid
    NY
    133Coins
    No. I reinstalled it and now it says it is patched but I need to run a race first. I keep running races but never get any motion. I've given up for now.
    152,553Coins
    +11,087 / 56 / -2
    You have to run a race before patching, so un-patch, close SimTools, run a race, then try re-patching.
  10. tomquid
    NY
    133Coins
    Thanks I will try that. I will let you know if it works (just have to put the rig back together - in the middle of a rebuild:)
  11. tomquid
    NY
    133Coins
    still no luck. I am back to step one again. I exit all simtools, run a race (I do a special rally event - one leg, also tried career). start simtools and try to patch to the dirt rally folder under 'documents'/'my games'/ 'dirt rally' but I still get the 'run one race first'.
  12. yobuddy
    51,211Coins
    Did you un-patch the game before exiting simtools?
    Are you on a 32bit or 64bit pc?
    What OS?
    I'm using the 2.0.0.3 version here.
  13. tomquid
    NY
    133Coins
    yes, unpatch, and exit simtools.
    then run some races and try to patch it, with no luck.
    running win10 64bit
    simtools game manger version 0.2.2.0
    152,553Coins
    +11,087 / 56 / -2
  15. tomquid
    NY
    133Coins
    thanks. l'll give that at try:) (I just bought the software so I guess I figured it was the latest version)
  16. tomquid
    NY
    133Coins
    still nothing. updated to version 0.2.2.5
    deleted the patch (from the appdata folder)
    exited simtools
    ran a race
    installed the patch
    "you must first install the game and run a race"
    exited simtools (no need to unpatch because it never patched in the first place)
    ran a race
    tried to patch but again got the "you must first install the game and run a race"
    152,553Coins
    +11,087 / 56 / -2
    Can you please download LFS and verify that SimTools is working with that, just to verify that your system is working correctly: https://www.lfs.net/downloads
  18. tomquid
    NY
    133Coins
    It is working perfectly fine with iracing and assetto corsa.
  19. tomquid
    NY
    133Coins
    I have a feeling I am not running 'a race' correctly. All I do is run a 'custom event' and then a quick rally stage. Should this be enough?
    152,553Coins
    +11,087 / 56 / -2
