Small Mige QR
Discussion in 'Direct Drive Wheels' started by Martyn, Mar 4, 2018.
  1. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    I´m thinking of jumping out of the Fanatec Rims to REALLY real ones:)
    What kind of Quick Release systems do you guys use?
    Will this one fit - i think i will have to use some spacer or something to mount it to mige..?
    https://www.aliexpress.com/item/May...53a4-4169-a41b-7af8908294b5&priceBeautifyAB=0
    Also, about the buttons on wheel - would love to make my own button box, i have read that it is possible to transmit signat via bluetooth to avoid using cables to wheel, any more info about that..?:)
    Many thanks, M.
  2. Ramok
    Ramok Member SimAxe Beta Tester Gold Contributor
    Slovenia
    1,130Coins
    Hi
    I don't recommended these QR is a carp. There is too much space between tooth.
  3. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Ok thanks, which one do you recommend then?:)
  4. Ramok
    Slovenia
    1,130Coins
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
    this is the buttonbox/wheel board to use. its bluetooth and comes with a built in charger. it even has a sweet gui to set up the buttons. it also recognizes encoders and will light leds. I have three of them they are awsome. no more wires.
    http://www.u-hid.com/home/overview_bboard.php
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
  7. Nick Moxley
    Upgrade to the printed versions,
    Haven't had one fail yet. And WAY WAY cheaper than what else is out there. Cough cough q1r
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
  9. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Many thanks for help! Yes Q1R is kinda prizey, specially when you need more wheels (rally, formula, gt´s...:)
    Well this 3d printed does not look bad really, i might still prefer aluminium one but have possibility to let make one locally - i see there are cnc plans for original one (super thanks to @RacingMat :), but are there cnc plans for the upgraded one @Nick Moxley ?:) would be greatly appreciated :)
    The U-HID looks so sweet also! And not that expensive.. So i guess if i take the $43 version with usb i can charge the lipo directly from usb? Great!! And it can also handle the led rev light for example? Via Simhub? That would be super cool:)
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    i use a micro for simhub its a different connection.
