value1
American Truck Simulator 2.0.2.1
SimTools game plugin for American Truck Simulator
  1. value1
    14,240Coins
    American Truck Simulator - SimTools game plugin for American Truck Simulator
  2. RaguTom
    RaguTom Cool Guy, Chronic Long-Winded Poster Gold Contributor
    Electronics Engineering/Technician
    Harrisburg, PA, USA
    337Coins
    If anyone is having issues getting motion to work with this plugin please check the game log file located in "C:\Users\[Your User name]\Documents\American Truck Simulator\game.log.txt
    Scroll to the bottom and look for the line that states that the game is trying to load the SimTools Plugin. If the next line says Unable to load: 0000007E, make sure you have VC redistributable 2015 installed from the Microsoft site. This plugin was written with the latest version of Visual Studio and needs to have this runtime installed!
    Tom
    • Informative Informative x 3
  3. value1
    14,240Coins
    That's very helpful information! Thanks, Tom :cheers
  4. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hell
    which is better to use axis .roll,pitch ,heave
    or surge,sway,heave?
    thanks
  5. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    i don't know why but i don'have any numbers coming from ATS in the tuning center and i have the same problem with ETS2. I re-installed the plugin v.2 (ETS2) but nothing :(
    any idea ?
  6. value1
    14,240Coins
    Can you try to move SimXperiencePlugin_1_0_64.dll away from D:/Steam/steamapps/common/American Truck Simulator/bin/win_x64/plugins/ and check, if you have data then?
  7. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    I tried it but nothing , i put the plugin on the desk but not better.
  8. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    i succeed with ATS and ETS2 , the both games works now but simvibe don't work anymore, conflict maybe ?
    i only changed the virgule for a decimal point in windows like here :
    ps : i re-patch the game too
  9. yobuddy
    51,536Coins
    try this maybe,
  10. value1
    14,240Coins
  11. patoch
    patoch l'AUvergnat de france Gold Contributor
    63000 clermont ferrand
    21Coins
    3DOF, SCN6
    the plugin that I have and get it if Americantruck.simulator plugin 2.0.0.1 that and no vavid how to get the right plugin thanks
    153,890Coins
    +11,154 / 57 / -2
  13. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello everyone,
    I have serious problems with the actuators movement in American Truck Simulator after the last update.
    Now as soon as I launch the game and try to start driving the left and right actuators move jerkily and it is almost impossible to drive.
    I noticed that opening the Game Engine Tuning Center the Game Data Output for Roll it is high (4820), while the value of Yaw is even exaggerated (78338).
    I also tried to depatch the plugin, delete it from its path and then reinstall it but unfortunately the problem persists.
    I inserted a situation screen... maybe someone could tell me how to solve!
    153,890Coins
    +11,154 / 57 / -2
    Manually add to higher TC values, then capture Max/Min and drive around a bit then save, refine after that.
  15. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Thx noorbeast... I tried to do as you said but things are even worse!
    The dynamic movements are completely wrong and strong... and I'm afraid to broken the actuators :(
    I enclose an image of the current situation in the Tuning Center and Game Manager, where I was forced to lower the value to 20 to try to avoid too abrupt movements but without success.
    surely I'm making some mistakes but unfortunately I'm really not very practical and I normally use the SimTools default values in all games.
    I hope you can help me to solve!
  16. BlazinH
    16,691Coins
    Lower tuning numbers make the forces more abrupt so make them larger not smaller.
  17. Sim-Department
    Sim-Department Motion Kits for Alu Rigs
    150Coins
    Motion platform
    I have problems too.
    My rig falls down on the rear and then it starts to move extreme in different directions.
    I am also afraid to destroy the actuators.
    Any idea?
  18. dhrto
    dhrto New Member Gold Contributor
    Netherlands
    - 45Coins
    3DOF, SCN6, Motion platform
    I had the same problem with ETS2 also. On my setup, it seems the game outputs in millidegrees and milli-G's, while the default values of the plugin in the tuning center is based on degrees and G's. Please try these values in the tuning center:
    Roll: max/min = 5000/-5000
    Pitch: max/min = 5000/-5000
    Heave: max/min = 2000/-2000
    Yaw: max/min = 180000/-180000
    Sway: max/min = 2000/-2000
    Surge: max/min = 2000/-2000
    Setup your axis assignments as you like, since that is very much dependent on your rig.
    Hope this helps. Please report back for others to know. Good luck!
  19. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    I tried simvibe with american truck simulator but it crashed (this was a few months ago) and now that i stopped using simvibe with this game, i get no motion AT ALL in game with simtools on. I tried changing all the axes and not a single movement. What do i to fix this?
  20. dhrto
    Netherlands
    - 45Coins
    Try doing a capture in the tuning center. Do you get any output values at all?
    If not, maybe something went wrong with the patching (try unpatch and patch again, make sure to select the right directory).
