SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    I'm using vJoy utility for that. It can combine multiple physical USB control devices into one virtual joystick. Axes and buttons are assignable, so you can use that to emulate XBOX gamepad as well. Good for games that don't support HOTAS and pedals in native mode.
  2. George Dobransky
    Hungary
    - 43Coins
  3. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Yep, that`s the one.
    No comparison in using joystick plugin vs dedicated Elite one though. Craig, you are our only hope :)
  4. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    919Coins
    3DOF, Arduino, Motion platform, 6DOF
    Well said 4apaev. I've been in joystick mode recently - and I've just upgraded my rig to 3dof and upped the power to 450w (from 80w). I too miss Craig's superior ED plugin. I miss the collateral motion from explosions, collisions, and having my chair move independently in relation to someone else's ship when I'm a crew member in multicrew. Maybe well get a motion api from FD soon? But I'm eagerly awaiting a Craig plugin in the meantime if possible.
  5. George Dobransky
    Hungary
    - 43Coins
    4apaev,
    Unfortunatelly, vjoy has been failed to install (win7), I tried many times and methods.... Joystick plugin is still with one stick
    to me....Craig is the last hope.....
    Cheers,
    George
  6. Deleted member 24758
    Waiting patiently for SilentChill to work his magic
  7. George Dobransky
    Hungary
    - 43Coins
    Hi All,
    According to the Frontier Expo last week, maybe we can hope something about API...
    In this way I wasn't hesitate to write to our contact person of FDev about API,
    if he can tell us something good. Here are my words:
    "Hi CMDR Tronador,
    If you remember we was talking about a stable telemetry (API) output from the game 2 months before.
    The informations at Frontier Expo last week was about the core elements of the game
    will be upgraded soon, so maybe can we hope for something about API also?
    Maybe at the first big update in Q1?
    BestRegards,
    George, Hungary "
    I'm waiting for the answer, as I get, I'll inform you all.
    Cheers,
    George
  8. George Dobransky
    Hungary
    - 43Coins
    Hi THere,
    Due to the continous updates and the fact we still don't have a working API output from the game, for those, who has got more than 1 usb connected joysticks or want some more programmed movements in the game I can offer you an alternate method to get movement with ED.
    Maybe it isn't new info to some of you, but maybe I can help to some.
    Joystick plugin only can manage 1 joystick input, so if you have stick, thrust and pedal separatelly with 2 or 3 usb inputs, you can use the software called vJoy, a virtual joystick device. you can download from here:
    https://sourceforge.net/projects/vjoystick/files/Beta 2.x/
    There is several versions, the new ones has a chance to get an installation problem with win7, or win10, in this
    case you can try an older version. I have spent some hours with that fcking issue....:(
    You need also a remapper utility, for new versions of vJoy there is UCR, link:
    https://github.com/evilC/UCR
    For older versions of vJoy, you can use UJR:
    http://evilc.com/fil...hk/vjoy/ujr.zip
    With these utils you can easily set up multiple joys or usb input into one, and a lot of advantages
    there, like you can program some movements to buttons, axes, etc. For example you can program any
    movement to landing gear down, or hyperjump, etc.
    Hope it helps you in these unhappy days....
    Cheers,
    George
  9. George Dobransky
    Hungary
    - 43Coins
    Hi There,
    My current config is, 2 x 12v motor system, smc3, mmShield, arduino.
    Now I'm planning to change to 3 x 24v motor(or actuator) system to simnulate heave also.
    Can anybody help me with a tutorial link about the motor controllers and the
    wiring of 24v motors to arduino?
    Thanx,
    George, Hungary
    153,866Coins
    +11,154 / 57 / -2
    You can use Sabertooths: https://www.xsimulator.net/community/faq/arduino-codes-for-sabertooth-2x25-2x32-etc.137/
  11. George Dobransky
    Hungary
    - 43Coins
    Thanx for help,
    George
  12. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Current version of Elite seems stable, maybe we can hope for the new plugin? Thargoids are waiting!
  13. cruzebabuze
    cruzebabuze Active Member
    135Coins
    hi everyone, I have installed it many times but game manager is not seeing it ? thank you in advance
    153,866Coins
    +11,154 / 57 / -2
    What SimTools License version are you using, as the Demo version won't list plugins other than LFS.
  15. cruzebabuze
    135Coins
    I am not using 2 I am using an old version
  16. noorbeast
    153,866Coins
    +11,154 / 57 / -2
    Plugins are not maintained for SimTools 1.3.
  17. cruzebabuze
    135Coins
    Ok thank you
  18. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    I am assuming this is still not working? I installed as an admin, everything went smooth but no motion. Wish I new before I paid for the game. Is the only option currently as described above?
    Thank you.
    153,866Coins
    +11,154 / 57 / -2
    When ED updates break the motion plugin then most fall back to the generic Joystick motion plugin: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    See here for @George Dobransky' instructions on using vJoy to map it how you want: https://www.xsimulator.net/communit...ns-plugin-vr-version.10310/page-4#post-142686
  20. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    hi Craig,
    Want to ask whether you could deliver an updated elite dangerous plugin . :sos
    Would be very appreciated, it’s really needed. We’re out of motion.
    Since I upgraded my motion rig with linear actuators I can’t wait to test it.
Thread Status:
