Question DCS 2.0 1.5 plugin no output data
Discussion in 'Digital Combat Simulators (DCS)' started by jpdesvals, Sep 19, 2017.
  1. jpdesvals
    jpdesvals New Member Gold Contributor
    new-caledonia
    134Coins
    Hello ,
    i did just buy the DIY version of simtools .
    recieve last month thanos acm 1280 6 dof board
    project will be a 6 DOF MP with 6 powerfull DC geared motors
    what i did so far :
    -game manager : plugin installed (folder check for good instal )+ game patched in in saved game\dcs or dcs open alpha : checked .lua created
    -game engine : -green flag and blue flag when game running
    -axis configured as thanos advised
    -game interface as thanos advised
    -firewall port checked udp 41230
    when game launched : no telemetry in virtual axis or tunning center
    thanos board connected and saying morors waiting for data ..
    i did also try the "no simulator method "as advised with jkr and axis assignement "to check output data without motion platform but no joy too ..
    hope there is a solution . i can't post picture for the moment as this is my second post .as soon as i will be able i will post them .
    what am i missing with these clues , any ideas ?
  2. jpdesvals
    new-caledonia
    134Coins
    Just for information i managed to get everything working with the LFS plugin ( i get output data )
    So i assume that the interface (game engine) and axis config(game engine ) are well configured .
    But no data with DCS plugin , is there another plugin totest with DCS openalpha ?
    145,160Coins
    +10,780 / 52 / -2
    Plugins are tested against the stated version and can be broken by updates.
    In addition it helps if you post pictures of all of your settings.
    Please do not duel post on the same issue, it just gets too confusing.
  4. jpdesvals
    new-caledonia
    134Coins
  5. jpdesvals
    new-caledonia
    134Coins
    OKI solved !!
    It was the Windows decimal separator problem as my pc is in french had to dig a little bit !!
    What a ... Dcs uses this decimal and not the other games.
  6. Arianus One
    Arianus One Tony Rom
    empleado
    - 8Coins
    donde consigo un plugin que está vigente desde el que se puede descargar desde la página no funciona. DCS mundo en 2dof está en la versión 2.5! 22 de de abril de 2018
    gretttings partners
    145,160Coins
    +10,780 / 52 / -2
    Google Translate -
    where I get a plugin that is valid from which you can download from the page does not work. DCS world in 2dof is in version 2.5! April 22, 2018 gretttings partners
    Please be aware that it is a forum requirement to include English, you can use Google Translate as I have done for you: https://www.xsimulator.net/community/threads/forum-rules.9527/
    A plugin has not yet been built for DCS 2.5, generally it is a nightmare to maintain a plugin when the game is constantly being changed.
  8. Arianus One
    empleado
    - 8Coins
    thanks for your quick response, I am new to this 2dof, you can retouch the plugin every time the game is updated or you will have to make yourself a totally new plugin every update of the dcs world or at least when fail the one that is already has ?
    I little english sorry,my lenguage is spanish
    I using google translator
    Greetings
  9. Arianus One
    empleado
    - 8Coins
    the plugins are not free, how is it that the developers do not keep them up to date, or at least not so old?
  10. Arianus One
    empleado
    - 8Coins
    My main reason for buying a 2dof system was the dcs world and it is a simulator that is updated often, a real problem for the 2dof or similar movement system, I have an oculus rift and a buttkicker gamer 2 and I just lacked this system of movement , but I see that it is complicated to use for the plugins
    145,160Coins
    +10,780 / 52 / -2
    Plugins are created by people who volunteer their time and expertise, they do not get paid for them.
    You can pay for plugin access with real or forum activity coins, the latter really is free access: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    You can find out more about the relationship and revenue sharing arrangement between SimTools (software) and Xsimulator.net (community support) here: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    You can make your own plugins, you don't have to wait for others to do it for you, you can find out more about creating plugins here: https://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
    If you look at what it takes to make plugins you can perhaps better appreciate why it is a huge amount of work to try and maintain a plugin for a game that does not provide a stable API, and hence which breaks the plugin every time a game is updated.
  12. Arianus One
    empleado
    - 8Coins
    thanks you very much :)
