Question 2 dof project
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by djaysam, Feb 17, 2017.
  1. djaysam
    djaysam djaysam
    pakistan
    266Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Joyrider, Motion platform, 4DOF
    thanks @speedy for detail explanation
    before i was using 1k pot today i replace it with 10 k
    now I got what @insanegr & @Pit was trying to tell. My bad understanding
    now i tried to hold pot and motor shaft like this picture
    now the smc3 utility is showing this type of reading
    now please guide me further
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,946Coins
    Give us a video ... :popcorn
  3. djaysam
    djaysam djaysam
    pakistan
    266Coins
    I have joined screw driver with motor shaft and hold the pot by hand please check in video
  4. Pit
    30,504Coins
    Great, you got it working, but the motors are way too "slow", you cannot do anything more. Are you sure the motors are only 12V motors?
  5. djaysam
    djaysam djaysam
    pakistan
    266Coins
    its 24 volt its old motor i will buy new viper 12volt motor when i succeed in simulating with my circuit
    what motor do you prefer ?
    can i use 24 volt motor ?
    can i move forward to my further setting or i need to buy 12volt motor first ?
  6. Pit
    30,504Coins
    MotoMonster supports up to 12V only (theoretically up to 16V but this does not work). On 24V your motors spin twice as fast but IMO still to slow for a motion rig. In this case you need an other motor driver.
  7. speedy
    Alexandria , Egypt
    7,946Coins
    You can't get accurate green to blue matching motion with this slow motor plus you holding the Feedback pot like that :grin ...
    It is quite obvious that this motor have a planetary gear on it's output which I guess causes the lage time reversing the output shaft/pot ... I can hear it moving internally before the pot actually reverses .
    You have succeeded in your job so far :thumbs ... go further and increase the PWMmin and PWMmax to get to the maximum speed for this motor ..
  8. djaysam
    djaysam djaysam
    pakistan
    266Coins
    kindly refer me a motor driver
  9. djaysam
    djaysam djaysam
    pakistan
    266Coins
    there is not much effect by increasing as @Pit advice me to change driver for my motor
  10. djaysam
    djaysam djaysam
    pakistan
    266Coins
    I have replaced my dc 24 volt motor with wiper 12 volt motor
    should we need to setup pot directly with motor ?
    i saw somewhere on youtube that pot is connected to motor from backside with extended shaft and from front shaft using for playseat so should i have to do the same as this motor is very fast and i cant handle it with pot in my hand
    do you have nay picture for reference for this motor
  11. Pit
    30,504Coins
    you can as long as the potis support the range of motion.
  12. speedy
    Alexandria , Egypt
    7,946Coins
    • Useful Useful x 2
  13. djaysam
    djaysam djaysam
    pakistan
    266Coins
    hello guys i am back . i have bought a wiper motor and make a back shaft for pot now my smc3 is like this smc3 after pot.png
  14. speedy
    Alexandria , Egypt
    7,946Coins
    Very Nice ... keep going . :thumbs
    To more enhance the square step => use the Ki & Kd to lower the oscillation , use 1/10 the amount of the Kp or lower ...
    To get a perfect position holding use some more 50 or 70 PWMmin to overcome the motor startup friction .
  15. djaysam
    djaysam djaysam
    pakistan
    266Coins
    hello please guide me
  16. speedy
    Alexandria , Egypt
    7,946Coins
  17. judges
    judges New Member
    309Coins
    "Understanding PID in 4 minutes"... You could as well speed up that vid by factor 10 and call it "Understanding PID in 24 seconds".. :p
  18. Pit
    30,504Coins
  19. djaysam
    djaysam djaysam
    pakistan
    266Coins
    @Pit you mean to say i should change the limits what would be the correct limits please share link
  20. SeatTime
    This will all depend on 'Your' rig - very unlikely that any two will ever be the same. Members have been kind enough to get you in the ballpark, but now you need to educate yourself so that you can do/understand yourself - instead of expecting every step to be done for you. Have a look at the FAQ - it is all there. Yes, you need to do some work.
