My simulator 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by kwak, Jan 17, 2017.
  1. kwak
    kwak Member
    - 324Coins
    I think I will format the computer :(
    153,812Coins
    +11,150 / 57 / -2
    It is a real pain but until we know what messes up localhost reinstalling may be the quickest resolution.
    Before you do would you mind downloading and running Belarc: http://www.belarc.com/free_download.html
    It is a useful record of your current install but may also be a basis to see if there is a pattern with the machines that have this particular problem, in terms of what software is installed and how the network is configured.
  3. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    nice work buddy!
  4. kwak
    kwak Member
    - 324Coins
    I will test before formatting thank you
  5. kwak
    kwak Member
    - 324Coins
    It is good I found it is a service that blocked the network Asusgamefirstservice by disabling it is OK
  6. kwak
    kwak Member
    - 324Coins
    How to adjust the Axes in play?
    153,812Coins
    +11,150 / 57 / -2
  8. kwak
    kwak Member
    - 324Coins
    thank you very much
    When I press the ON button I have an error and gamemanager quit
    153,812Coins
    +11,150 / 57 / -2
    What error message does it give when it quits?
  10. kwak
    kwak Member
    - 324Coins
    I have this message that on some plug-ins
  11. kwak
    kwak Member
    - 324Coins
  12. kwak
    kwak Member
    - 324Coins
    No one to this problem?
  13. WimmerRacing
    WimmerRacing New Member
    Atascadero, CA, USA
    246Coins
    3DOF, DC motor
    Did you find a solution to this error?
    I get the same error after disabling ASUS service (which resolved the NOT CONNECTED for me).
  14. kwak
    kwak Member
    - 324Coins
    With the simtools vrsion 2.1 it works
  15. kwak
    kwak Member
    - 324Coins
    I now have other problems projects cars 2 is not working :(
  16. noorbeast
    153,812Coins
    +11,150 / 57 / -2
