Anatolie's build
Discussion in 'DIY Motion Simulator Projects' started by anatolie, Dec 18, 2016.
  1. anatolie
    anatolie New Member
    SPAIN
    118Coins
    Hello can you help me with ibt-2 do not move the motors
    153,890Coins
    +11,154 / 57 / -2
    Saying something does not work is not enough information, you need to provide a bit more detail about what you have and have not done.
  3. anatolie
    anatolie New Member
    SPAIN
    118Coins
  4. anatolie
    anatolie New Member
    SPAIN
    118Coins
    I have to connect the potentiometer?
    153,890Coins
    +11,154 / 57 / -2
    Where are the pots?
    What are the motors and do they need ground isolation?
  6. anatolie
    anatolie New Member
    SPAIN
    118Coins
    • Old Old x 1
  7. anatolie
    anatolie New Member
    SPAIN
    118Coins
    How to insulate motors
  8. anatolie
    anatolie New Member
    SPAIN
    118Coins
    isolacion motor
    153,890Coins
    +11,154 / 57 / -2
  10. Historiker
    9,205Coins
    Anatolie, I created a build thread for you and moved your posts as they are not on topic in the previous thread. You will be more likely to get the help that you need here. Please edit the first post with more information on what you plan with this build.
    Good luck and I look forward to seeing what you come up with. :thumbs
  11. Radioproffi
    Lviv
    1,677Coins
    I think PWMmax - 28 not enough for move.
  12. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @anatolie did you change the line in the arduino sketch to MODE 2 before uploading it to your arduino ?
  13. obobo
    obobo Active Member
    1,323Coins
    I find that the fixings of the engines are too weak
    You should be able to fix your potentiometers with a reduction to gain in precision and not to destroy them because of the couplings
    Are the sections of electric wires not just right?
  14. anatolie
    anatolie New Member
    SPAIN
    118Coins
    Hello how to configure the sim tools to start the simulator movement for game
    153,890Coins
    +11,154 / 57 / -2
    Your question does not belong in this thread, you can either start your own build thread or post questions in a new thread here: https://www.xsimulator.net/community/forums/diy-motion-simulator-building-q-a-faq.31/
    The Admins @Historiker or @RaceRay can help move this for you.
    With respect to your question the hardware and control boards need to first be set up correctly. You would need to tell members about your hardware for them to be able to assist.
    Next you need to interface your hardware and to do so check out the SimTools documentation can be here: https://www.xsimulator.net/simtools-complete-documentation/
    Once SimTools has been configured correctly to interface with your hardware then you need to go through the steps to create a motion profile for each of your games: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  16. Historiker
    9,205Coins
    Moved.
  17. anatolie
    anatolie New Member
    SPAIN
    118Coins
    I am with sim tools load from the beginning when it is ready I answer you thank you
  18. anatolie
    anatolie New Member
    SPAIN
    118Coins
    Hello how to adjust potentiomstros do not move motors with sim tools
    153,890Coins
    +11,154 / 57 / -2
    As I mentioned earlier further information is needed.
    You need to read the documentation and tell members what hardware you have, any code it is running and post screenshots of any and all configuration settings.
  20. anatolie
    anatolie New Member
    SPAIN
    118Coins
    I have arduino r3 with ibt-2 with smc3 utils the engines aranca but with sim tools I can not load the motors
