12v 200w 50:1 Motors
Discussion in 'Motor actuators and drivers' started by Kurtis Bell, Sep 19, 2014.
  1. Kurtis Bell
    Kurtis Bell New Member
    452Coins
    Has anyone ordered these motors with the 50:1 box? or know this information to be true in this listing? Seems ambitious to say the least. Im also really curious if these have a lot of back drive like the 25:1 (freewheel).
    http://www.ebay.com/itm/351093944483?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  2. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Hi Kurtis, i have four of them motors in my sim and have to say I love them, very powerfull and staying cool also.
    It took a week to get them from Canada to Belgium with air mail.
  3. Kurtis Bell
    452Coins
    @AI.bundy did you get them from this seller? And are they the 50:1? I have seen a lot of the 25:1 used but none of the 50:1. Do they have any back turn?
  4. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Yes I got them from the seller named pgsaw, and i believe they are 50:1, back turn ?? Do you mean they move backwards ? Once they are powered they are not moving backwards at all, hope this helps...
  5. Kurtis Bell
    452Coins
    Back turn as in when they are turned off completely. Will they hold the sim stable or will they move when weight is forced on them
  6. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Yess when power is off then they move, no problem at all for me though, i allways start up the sim and then i enter it so to speak.
  7. Kurtis Bell
    452Coins
    Oh ok that makes sense, so with the fact that they have to be energized 100% of playtime do you have any overheating issues? About how much weight are you throwing on them? Or maybe a pic of your setup :)
  8. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    My weight is only 60kg so not much but a friend weighing 85kg also tested the sim, no problems at all, I have built the sim very solid, the motors stay very cool also do the jrk,s , i have them in an old psu box with only one fan on them, but it seems enough to keep them nice and cool.
    At the moment I am just testing the sim while I wait for the mail to arive, i ordered another potentio meter to get my traction loss working.......
    The sim is powered the simple but efficient way, i just use a 45 amp car battery with a loader and it works very well indeed.
  9. Kurtis Bell
    452Coins
    Awsome! Thanks for the help :)
  10. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
  11. Nick Moxley
    17,054Coins
    "motor locks for when not powered"
    • Creative Creative x 3
  12. bsft
    the 50:1 and 60:1 boxes are near impossible to turn by hand with the power off.
    The 25:1 are easy to turn.
  13. Nick Moxley
    17,054Coins
    What if you Sit in the chair and wobble around ? Will the magnets/gearing let go then ? I know at first when my motor's were Brand new and tight the motor's would hold a good bit but as soon as they "broke in" the seems to be a little looser.
  14. Kurtis Bell
    452Coins
    Thats what HE said ^^ :p hahaha
  15. Yoder_
    Yoder_ New Member
    IT Dude
    Oklahoma, USA
    400Coins
    Just ordered two of these 25:1's today. I'll let you know how they work out.
  16. masterhoo
    masterhoo New Member
    Peru
    370Coins
    Hi @Al.Bundy, I'm about to order online two of this motor type, I know this post is a little old, but could you or someone let me know how to attach the motor shaft of this model to the main levers & potentiomenters? Do I need to buy especific gears/couplings? thank you.
  17. noorbeast
    145,196Coins
    +10,781 / 52 / -2
    The FAQs have some useful guides for both:
    https://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
    https://www.xsimulator.net/community/faq/how-to-attach-levers-to-wormdrive-gearboxes.182/
  18. masterhoo
    Peru
    370Coins
  19. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    I just put a bolt trough the shaft of the motor, same as Nick Moxley did....see his pics above,
    so sorry for late answer :( wayyy too many projects.....
  20. Nick Moxley
    17,054Coins
    PLEASE use Nylon nuts, or to be extra sure a standard nut, followed by a Nylon nut to ensure thing's cant wiggle loose. ;)
