Question X Plane 11 plugin - game data output
Discussion in 'SimTools DIY Version' started by Lol4, Jul 3, 2018.
  1. Lol4
    Lol4 Member
    Australia
    - 115Coins
    X Plane 11 plugin - game data output. I am having jerky motion. Does the game output data in tuning centre look correct for straight and level flight? See attached screen shot. Thanks
    154,238Coins
    +11,176 / 57 / -2
  3. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Thanks I have tried that a few times the screen shot is after a few resets and hence the zeroes as taken between setting max max mins. . It was working fine but something has changed. I thought the values looked different to what they used to be? I thought maybe they were nearer zero rather than -90 etc when level?
    154,238Coins
    +11,176 / 57 / -2
    Yes the values would look different as zero is not a helpful default setting. So please run the Capture Min Max, that will create a base to tune from.
  5. Lol4
    Lol4 Member
    Australia
    - 115Coins
    So problem I think was when Xplane updated extra output values were selected in the settings menu of Xplane. I did a few things all at once so not exactly sure if you need to do anything other than untick the extra output settings in Xplane but I deleted all reference in the App/LocalData/simtools minmax config files etc related to Xplane. reinstalled plugin Repatched, rebooted and all is fine now. The output values now look right now (based more off zero so if anyone sees that they look a bit weird it is probably worth checking the Xplane data output settings tick boxes. Thanks for your help.
