value1
Wreckfest Plugin 2.0.1.3
Simtools game plugin for Wreckfest 32bit
  1. value1
    14,261Coins
    Wreckfest Plugin - Simtools game plugin for Wreckfest 32bit
  2. value1
    14,261Coins
    Now the funny thing about this plugin is that I'm not going to update it.
    Should there be an update of the game, I leave it up to you to find the new pointers to speed, acceleration and the transformation matrix. PrinceHairSlick_small.gif
    Therefore some hints:
    • Find a stable pointer to the speed vector, for example with CheatEngine. The speed vector consists of three consecutive memory locations storing the actual speed of the car in world coordinates.
    • Find a stable pointer to the acceleration vector. Again, it consists of three consecutive memory locations storing the actual acceleration of the car in world coordinates.
    • Find the transformation matrix, that is needed to transform the vectors from world coordinates to local coordinates (e.g. surge, sway, heave acceleration, etc.)
    Enter the offsets into the file
    C:\Users\<User>\AppData\Local\SimTools\GamePlugins\Wreckfest_Offsets.xml.
    When you find a pointer with 2 offsets, write
    Offsets="2".
    Offset_0 is the value behind "Wreckfest.exe"
    Offset_1 is the second offset (e.g. 3F0)
    All offsets must be entered in hexadecimal notation.
    Code:
    <?xml version="1.0" encoding="UTF-8" ?>
    <!-- 2018-July-14 -->
    <!-- Wreckfest 1.232998 32bit DX11 -->
    <!-- Pointers by value1 -->
    <!-- all values in hex -->
    <pointers>
        <Matrix
            Offsets="2"
            Offset_0="D55450"
            Offset_1="3F0"
            Offset_2 ="0"
            Offset_3 ="0"
            Offset_4 ="0"
            Offset_5 ="0"/>
        <Speed
            Offsets="2"
            Offset_0="D557B0"
            Offset_1="3C"
            Offset_2 ="0"
            Offset_3 ="0"
            Offset_4 ="0"
            Offset_5 ="0"/>
        <Acceleration
            Offsets="2"
            Offset_0="D557B0"
            Offset_1="48"
            Offset_2 ="0"
            Offset_3 ="0"
            Offset_4 ="0"
            Offset_5 ="0"/>
    </pointers>
    Good luck!
    • Winner Winner x 3
  3. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Thanks so much!
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
    Thank you!
    I started to write the plugin for this game, but this method is hard to find good values (except gear and speed)
  5. value1
    14,261Coins
    Yes, indeed, it needs some passion, some time and some good coffee :)
    And once you have found stable pointers, you still have to verify they work in different modules in the game (which should be the case for Wreckfest) and on different machines.
  6. EL mansouri
    EL mansouri New Member
    - 49Coins
    adieu cher ami d'abord vous remercier de cet effort fourni pour le plug-in pour wreckfest, mais m'a dit qu'il sera mise au point lorsque s'il vous plaît, je suis un novice en informatique, merci de nous coordonner ai_der
    154,238Coins
    +11,176 / 57 / -2
    Google Translate -
    goodbye dear friend first thank you for this effort provided for the plug-in for wreckfest, but told me it will be fine tuned when please, i'm a computer novice, thanks for coordinating us help
  8. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Ill do all of that, once I figure out what any of it means! Thanks for sticking with it for us masochists who want motion on this roller coaster!
  9. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    I had trouble getting this to read on my PC. The trick apparently was to launch the 64 bit version after patching, then go back to the 32 and it worked. No idea why, maybe just a fluke.
  10. leonaikikai
    leonaikikai Member Gold Contributor
    45Coins
    I hope 64bit version please
    Big thancks for your job
  11. SEHATanguy
    SEHATanguy Member
    Belgium
    96Coins
    Thank you! I'll give it a try
  12. value1
    14,261Coins
    Not sure if there will be a 64bit plugin. But you can force Wreckfest into 32bit mode with the startup option. I guess, there's not really a difference between 64bit and 32bit mode.
  13. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Just make sure you actually launch it from Steam, not from the taskbar selection. It will not give you the choice if you launch from the taskbar. I have zero performance difference between 32 and 64.
  14. leonaikikai
    45Coins
    Thanks guy the game run in launching 32bit mode :thumbs
  15. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    Many thx for plugin !
    in multiplayer, when we are waiting for the end of a race the camera follow a player as an observer and the cockpit is mouving, if there is 10 minutes waiting I get shake full , any idea to stop what ?
  16. noorbeast
    154,238Coins
    +11,176 / 57 / -2
    You can disconnect SimTools using the button on the top left of Game Manager.
  17. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    many thx , this button make a cockpit in standby mod ?
  18. noorbeast
    154,238Coins
    +11,176 / 57 / -2
    Sort of, Game Manager will be disconnected and you can click it again to reconnect when you want motion.
  19. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    ok , very good !
    i try to play multiplayer but something wrong, the motion is not like my car , it's like the motion another player
  20. leonaikikai
    45Coins
    thank for that because i have the same problem
