Wich motor to use with 6dof
Discussion in 'Motor actuators and drivers' started by waldo wautelet, Nov 21, 2018.
Tags:
  1. waldo wautelet
    waldo wautelet You found me...
    Belgium herent
    165Coins
  2. Thanos
    Electronics Engineer
    United States
    2,854Coins
    Each servo drive is matched from the factory for certain servomotor. If you get them separate you will have to match them manually (encoder parameters, servo coil timings, PID calibration). Many of these servos in the market do this calibration via CAN or RS485, but its hard to find the software for it and if available could be in Chinese.
    Also make sure you can get a servo drive from source that can provide support (for settings and interface connections) as if you are going to rely only on the manual that the seller may give you, you may get stuck to nowhere.
    Do you have a plan how you are going to control the servo drives? Any certain interface? I assume you want to use it with simtools, not for CNC application...
  3. waldo wautelet
    Belgium herent
    165Coins
    Yes I would like it to work with simtools !
