    Buy Download Package Now!
Question Which rig should I start building up to 2500$
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by rocendroll, Jul 24, 2018.
  1. rocendroll
    rocendroll New Member
    84Coins
    So basically I'm trying to get bang for my buck, and I was thinking about buying used rig or bulding my own.
    I'm interested about maximum I can get, buy not sure what 2,5k can get me. Could you help me, and tell me what I can look upto in that budget?
    What I pretty certain about is that I would be looking for a Direct Drive wheel, and as many DOF as I can get. 3 seems reasonable - but if I could build myself 6DOF in that price, that would be awesome ;) Also, I would be picking some VR equimpment, but not sure at the moment what is best option for me
  2. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    470Coins
    3DOF, DC motor, SCN5, Arduino
    Well $1000 for a wheel leaves you $1500. So 3dof worm gear would fit in your budget. Or 2 dof scn. As long as you have some fabrication skills to make a solid frame with out have to use aluminum extrusion
  3. rocendroll
    84Coins
    Thanks, do you mean this?
    https://www.xsimulator.net/community/threads/simu-3dof-scn5.11834/
    Yeah, I could do something myself, it's not a problem, more the budget. Why should I pay so much for the wheel and what should I pick? Also, what rig to build?
  4. Cantago_NL
    Cantago_NL Member
    347Coins
    For that budget, why would you want everything at once? Why not start with a simple rig and a good wheel, and later go for a motion rig?
  5. sam poole
    sam poole Active Member Gold Contributor
    midlands
    641Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    I managed to build a crude 6 dof prototype for less than £600 plus £300 for seat and pedals and works surprising well so if you're resourceful you can get a lot for that money just make sure you don't buy until you know what you need
  6. PiaMan
    470Coins
    Because you said that you wanted a direct drive wheel and that is about the price of one. As far as choice i can say good things about osw and the bodnar steering system ($1000/$3000ish) but dont have experience with the other options. Id say you cant go wrong with osw but i know there are starting to be more options available
  7. Cantago_NL
    Cantago_NL Member
    347Coins
    Don't forget the new Fanatec DD1, $1000,- and looking very promising.
