wheelchair motor speed
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by bob golding, Mar 31, 2022.
  1. bob golding
    bob golding Member Gold Contributor
    retired
    penzance
    410Coins
    i now have all my motors. i have checked the speed and they are all aound 125rpm. doing some numbers i come up with 243mm/sec with a 150mm crank. they are 250 watt. i assume this is continously rated. a lot more for short periods. i dont know the stall torque as i have not got a way of easily checking it. at 250 watts and 125 rpm i come up with a torque of around 20nM at a crank length of 150mm. this seems a bit low to me. or is that the motors are used in more of a intermittent mode.?
  2. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    In my case, for example, I get 60rpm on the output shaft of the gearbox, with a 10cm lever, for me it is enough
  3. SaintFrank
    SaintFrank Active Member
    Proces operator
    Nederland
    232Coins
  4. David1982
    David1982 New Member
    Mecanico
    España
    63Coins
    Hello mate,
    Is it from the range?
    MY1016
    I tell you because there are 3 in the 250w range
    MY1016Z
    MY1016Z2
    MY1016ZL
  5. bob golding
    retired
    penzance
    410Coins
    no model nos on some of them so basing the 250 watts on the average rating for wheelchair motors. yhey are all around the same speed.
