Ways to install potentiometers
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Cale, Jan 17, 2017.
  1. Cale
    Cale Member
    Australia
    490Coins
    Hi guys just wonderng if you have any links to different ways to install potentiometers? Im going to be using 180deg hall sensors on ac motors/gearboxes.
    Is there any simpler ways of mounting that are durable and accurate that doesnt involve using gears as i have seen in some builds?
    Pictures or links would be appreciated.
    Thanks!
  2. Tim McGuire
    Canada
    2,203Coins
    3DOF, DC motor
  3. Cale
    Cale Member
    Australia
    490Coins
    @Tim McGuire thanks for the link. I like the flexible coupler idea....so let me understand this.....the flexible coupler is attached to the motor shaft so it will rotate with the shaft. The hall sensor then just sits loosly inside the coupler to then sense the shaft moving around. I then mount the hall sensor to a bracket which i attach to the motor to stabilise the hall sensor sitting inside the coupler?
    Thanks.
    150,686Coins
    +11,018 / 55 / -2
    The Hall sensor is supported by a mount bracket but the correct size flexible coupling tightens to grip the sensor and the motor shafts, so any movement is 1:1.
    Being flexible the coupling takes load off the sensor for any minor misalignment.
  5. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    I did my pot setup on AC like you are suggesting noorbeast - and it worked pretty well.
    I finally decided on designing a mount affixed to gearhead / then used aluminum pulley's and timing belt.
    I had to do the second way as I was having some "gearhead body flex" that would not allow to continuous accurate readings. Cost me about 35.00 us PLUS an afternoon to build the
    steel mounts for them.
  6. Cale
    Cale Member
    Australia
    490Coins
    @noorbeast thanks for the reply. So basically the hall sensor is tightened in the coupling along with the shaft so they both rotate in sync with each other but the coupling can also flex slightly if needed? The bracket is then used with a hole through it for the hall sensor to go through to keep it in a rough position so it doesnt actually attach to the sensor? If this is the case do you really need the bracket or can i just use the coupling?
    Also how would i go about using the coupling if my motor shaft is 24mm. Thats much wider than the 12mm coupling posted earlier.
    Thanks.
    150,686Coins
    +11,018 / 55 / -2
    The bracket holds the outer Hall sensor housing tight, the pot shaft tuns with the motor.
  8. Cale
    Cale Member
    Australia
    490Coins
    @noorbeast ok im with you now! So what are the best methods of holding the head of the hall sensor in place with a bracket? I see some use glue... but is there any other better ways? Also is it best to mount the bracket onto the motor so the sensor moves with movement of the motor or attach the bracket to my simulator frame for more stability.
    Thanks.
    150,686Coins
    +11,018 / 55 / -2
    The Hall sensor comes with a threaded housing and lock nut, so just drill the correct size hole in the bracket, slip the Hall sensor in and tighten the nut.
  10. Cale
    Cale Member
    Australia
    490Coins
    Im with you....probably would have helped if i had the hall sensors already to avoid many silly questions but i got it in the end.
    Thanks!
  11. Cale
    Cale Member
    Australia
    490Coins
    @noorbeast what about going from a 24mm shaft into the pot...the coupler is too small for that to work...any ideas on how to make that work?
  12. noorbeast
    150,686Coins
    +11,018 / 55 / -2
