VR SUPERPOSITION BENCHMARK - post your results!
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Pit, Apr 16, 2017.
  1. Pit
    30,510Coins
    you wanna know how your PC is performing in comparison with other PCs?
    The SUPERPOSITION BENCHMARK is a brand new GPU stress-testing tool from UNIGINE. It also features interactive VR experience with support for Oculus Rift and HTC Vive.
    Download: https://unigine.com/en/products/benchmarks/superposition
    Please select VR Optimum, either HTC Vive or Oculus Rift (or ideally both) and upload your results under this posting.
  2. Pit
    30,510Coins
    AFAYCS my PC using the GTX 670 is not yet VR "ready", it will work but you can't have everything...just curious how the 1080 TI will outperform in my xeon system
  3. Pit
    30,510Coins
    HTC Benchmark:
    154,052Coins
    +11,167 / 57 / -2
    Unfortunately the base version does not run in VR, you have to get the paid version for that, so it just displays a side by side on the monitor.
    I ran it on my portable little VR rig which also had a huge number of tabs open in Firefox, and was running Unity, Substance Designer, VS 2015, Explorer and Notepad.
  5. Pit
    30,510Coins
    The GTX 970 runs smoothly, may you test your system with VR Optimum?
    154,052Coins
    +11,167 / 57 / -2
    Here you go.
    If I had the time I would shut everything down and overclock this little beastie to see how it would go, but I am far too busy at the moment. When dad finally decides he is ready for me to build him a VR puter for his flight simulator then he will inherit the GTX970 and a 1080Ti will replace it in my portable VR rig.
  7. Pit
    30,510Coins
    Still great performance, as you have mentioned your cpu has much more room for improvement (@), as well your GTX by simply setting a higher power target, even without overclocking my GTX 670 card I got much better results only by using a higher power target. It is highly recommended to check the temperature, setting sliders too high could cause the video card to overheat.
  8. SilentChill
    20,601Coins
  9. Pit
    30,510Coins
    Average 200fps, that's a lot, the 980 ti is stunningly faster than the 970, despite of the CPU which is different in comparison with Noorbeast, of course.
  10. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  11. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Vive
  12. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Rift
    Just thought I would try this on the Future setting, think I'll have to wait for the 1480Ti for that.:)
  13. judges
    judges New Member
    309Coins
    Apparently the Superposition Benchmark does not come with a SLI profile (yet).
    So here are the results out of the box (results were pretty much identical, no matter if SLI is enabled or disabled in Nvidia control panel):
    These are the results after some SLI tweaking with "Nvidia Profile Inspector":
  14. Blame73
    Blame73 Well-Known Member
    8,314Coins
    4670k @4.4 Ghz
    MSI Gtx 1060 OC
  15. Blame73
    8,314Coins
    Your CPU is bottlenecking the GPU
    You got my score (FPS average) with a 1070 (I got a 1060) and almost the same CPU
    And that's a good info (for me) because I was going to update to a 1070/1080 but without also changing the CPU is pointless...
  16. Pit
    30,510Coins
    mates, I got my MSI 1080 TI Gaming today. First I did the test using VR Optimum, but the card showed an utilization of 50% only...so I tried the VR Future benchmark, rendering up to 10'000'000 triangles and over EDIT 100 /EDIT light sources...the hell on earth! Now the TI was fully utilized (100%) and - surprisingly - still showing acceptable fps:
  17. Pit
    30,510Coins
    Now OR VR Optimum:
  18. Blame73
    8,314Coins
    You got a huge bottleneck with your CPU mate, with the same settings the score is lower than my 1060!
    Max GPU utilization 61%!!
  19. Pit
    30,510Coins
    please also try VR future, small update:
  20. Pit
    30,510Coins
    tested VRMark, it says my system is better than 87% of all results...at the moment I'm happy with my "old" 6 core xeons, anyway I have spent a lot of money now, the xeons must do the job the next few months
