Resolved Trouble with NoLimits 2
Discussion in 'SimTools Plugins' started by Lasagna Smoothie, Mar 3, 2017.
  1. Lasagna Smoothie
    Lasagna Smoothie Member Gold Contributor
    New Hampshire
    399Coins
    I can't seem to get the plugin for NoLimits 2 to work. I'm running simtools 2.1. I've installed the NoLimits 2 plugin, patched the game (the game manager says "connected"), and I've gone into steam and added "--telemetry" to the launch options. Unfortunately, however, when I start the game I get absolutely no data in the simtools tuning window - everything is just straight zeros.
    I have steam and all of my games installed on a drive other than the C drive, so perhaps this is the issue? Maybe the plugin isn't properly patched because it can't find the game? When I patch the game I'm not given the option of selecting the file location as it simply says "no pathway required." Thanks in advance to any willing to help.
  2. yobuddy
    50,290Coins
    I'm sure someone will chime in that has actually used this plugin, but I don't believe the demo sends out telemetry?
    Are you using the full game or a demo buddy?
  3. Lasagna Smoothie
    New Hampshire
    399Coins
    Thanks for chiming in. I'm using the full version of the game. That was a good guess though.
  4. yobuddy
    50,290Coins
    Maybe try launching it from the command line with the "--telemetry" option?
    Just to see if the launch options are getting recognized?
    Should be something simple, as I know people have used this plugin.
  5. Lasagna Smoothie
    New Hampshire
    399Coins
    I have it working now. I'm not certain exactly what I did to get it work. I re-installed the plugin as well as deleted some residual files from the demo, so perhaps that had something to do with it. Regardless, thank you very much for your suggestions.
    150,542Coins
    +11,017 / 55 / -2
  7. Lasagna Smoothie
    New Hampshire
    399Coins
  8. yobuddy
    50,290Coins
  9. Lasagna Smoothie
    New Hampshire
    399Coins
    Thanks! I really appreciate your help.
  10. slipstream
    slipstream Airborne
    508Coins
    I’m having the same problem. Purchased the full sim but I have no movement. DOFreality 2 dof. Any ideas? I had demo mode but uninstalled this. Re patched. It did not ask for a path on either.
    150,542Coins
    +11,017 / 55 / -2
  12. slipstream
    slipstream Airborne
    508Coins
    All working now thanks yobuddy.
  13. slipstream
    slipstream Airborne
    508Coins
    Just to confirm my assignments. I have pitch and roll only. Is this correct? Can I assign others such as surge and heave? It’s working ok but just wondering if I can simulate acceleration on a 2 dof platform?
  14. noorbeast
    150,542Coins
    +11,017 / 55 / -2
    You can and should use surge, sway, heave, roll and pitch, even on a 2DOF, see here regarding how to refine a motion profile, initially doing one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the plugin does not work correctly the effects are very weak there is a particular setting thank you.
  16. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    use the tuning center to get good values.
    Look up the FAQs to see how tuning center works.
    Cheers ART FLY
