Triple screen setups
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dre99gsx, Feb 14, 2009.
  1. dre99gsx
    dre99gsx New Member
    Anyone willing to share some photos / mock ups of triple screens with their Frex-like design? Looking for ideas.
  2. Fahim
    Fahim Member
    307Coins
    Yeah I am looking into triple screen too. I can do with some advice please:
    I have found:
    40inch Samsung hdtv for around £350 each
    37inch Sony hdtv for £400
    What is better for triple screen? Is 40 too big?
    Is the 37inch x 3 the perfect size. I understand that with triple screen setup the image becomes larger???
    I have 40inch single screen setup as present but worried if I get 2 more 40inch it would just be too big.
    I rather have smaller if it means being more realistic.
    ALSO without opening the pc tower I looked on online manual and it says it has:
    1x PCI Express 16x
    1x PCI Express 1x
    2x PCI, 4x SATA
    Where does a graphics card go into as I will need another nvdia 9600gt (512mb) please?
    Many Thanks.
  3. DangerDan
    DangerDan New Member
  4. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    The size of the screens will depend on how far away you want to sit. There are many that run 21 to 24 screens and say that you don't need to go bigger but they have to sit 12 to 15 away from the screen which is way to close for my preference. With the larger screens, you also get a better lifesize representation of of the objects on screen.
    When choosing LCD tv's try and find ones with the smallest possible bezel size. I don't think you will go wrong with either the 37 or the 40 but try to get 3 of the same screen.
    Fahim, the most cost effective and easiest way to get a triple screen setup is to use a single ATI video card that supports Eyefinity, you can use the low cost 5770 or you can go to the 58xx series for better performance. This card would replace the existing card that you have. You will also need an active displayport to DVI adapter to run the 3rd screen when using the ATI solution. These usually run for about $80 to $100.
    You can take a look at my 3 screen setup in my simulator build thread ledfoot-s-2dof-simulator-project-t1936-80.html
    Dangerdan, very nice screen setup man :cheers:
  5. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    I use 3x22 with Eyefinity (HD5870) and honestly I would not go more then 3x24 ... or else I would buy a single 42 to 60 inches lcd or use one projector ...
    I personnaly think that the FOV is just unrealistic with larger 3x screens setups ... If we could use very aggressive side monitors angle it would be pretty cool and the immersion would be very interresting but we just can't because of image distortion we would get ... On setups using very large 3x lcd's, it looks like you are sitting in a tank instead of a racing car which is a total turn off for me ... (very personal opinion :) ).
    And I am sitting around 32 inches from the center screen which I think is perfect with lower FOV values. With over 60 inches of monitor wide I think I can represent pretty well a realistic cockpit interior size with proper FOV settings.
    The great thing about Eyefinity is that it's simply plug and play with pretty much all available games. You simply need to set the proper resolution in game settings. You will also get much more FPS (using the same GPU) than if you use other cheaper options like Softh and even with the internal Iracing tool to rander 3 screens separately ... You can also mount them in portrait mode to give you more height ...
    You also have to consider the GPU performance you are looking for... If you are like me and like to set every graphical setting to maximum on lattest games then forget 1080 or 1200 lcd's for triple screen setup or you will need something even more powerfull like the Ati HD5970. I am currently running a 5040x1050 resolution (HD5870, Core I7) and I can still set latest games to max settings except for AA which I usually set to first or second level on latest games (Dirt2, NFS Shift, IRacing...) to get a very smooth graphical feeling even with tons of cars on the grid.
    Here is a pic without the motion frame (waiting for my 8020 aluminium pieces and still thinking of the design ...)
    http://i141.photobucket.com/albums/r77/bleco04/cockpit.jpg
    Bleco
  6. Muzza
    Muzza New Member
    Sunshine Coast Australia
    I have just purchased 3- 27 Samsung panels to compliment my ATI HD 5970 and it works like a dream, plenty big enough and smooth as silk on my 2.4ghz Quad core pc. The Eye Infinity setup is perfect for multi screen setups as mentioned above. I purchased my display port to DVI for $25AU from Mwave.com.au
    I like the idea of larger screens as the realism is possibly increased as objects and cars become more life sized but fear it would be like watching tennis with all that picture to take in.
    Im happy with the size of my screens, any bigger and I would need to dedicate an entire room for my sim, I cant imagine my wife would be too impressed LOL!
    Im sorry I dont have any pics, Im still completing my monitor stand and should have it all up and running by Monday.
    Like Ledfoot mentioned, small bezel is the key and make sure your monitors can be wall mounted or easy to mount together in a frame etc. It took me a day to make my frame as there were no mounting points on the back on the screens. There werent too many available optoins when I bought mine, some were out of stock and I needed to make sure that all screens were the same make and model.
    Murray..
  7. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    Are you referring to this adapter?
    Mwave SKU# 10080174
    Because everywhere I have read about this ATI Eyefinity feature; requires you to use an active display port adapter, which costs about USD 100 plus tax, how is it that you have successfully made it work with this one of $25 bucks?
    Please advise
    Robert :cheers:
  8. Muzza
    Muzza New Member
  9. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    A DP to VGA adapter is in fact an active adapter since it convertes the video signal from one form to another. The DP to VGA adapters work in some cases but results will vary based on monitors being used. The DP to DVI active adapters are more expensive but are the recommend method for connecting a non displayport monitor to the DP on the video card.
  10. bleco
    Montréal, Canada
    258Coins
  11. Muzza
    Muzza New Member
    I didnt see mine on that list but its made by HP if that helps anyone searching for a more affordable option. It works perfectly.
