Question Transtechnick SMB823003 servo for 6DOF motion platform?
Discussion in 'Motor actuators and drivers' started by FoxONe42, May 12, 2019.
  1. FoxONe42
    FoxONe42 6DOF newbie
    Flight simulator engineer
    Nantes France
    102Coins
    Arduino, 6DOF
    Hi all,
    I have been looking into the build of a 6DOF motion platform for quite a long time but I am stuck with the choice of motor to use for the build. Obviously it is an important decision given the investiment, I don't want to make a mistake, thus my question here.
    In the company I work for, they are using the following servo motor for different applications:
    Link to the PDF doc (in french only)
    http://www.etranstechnik.fr/doc/pdf/rotatif_servomoteurs_SMB.pdf
    The nominal torque is 2.7 Nm, 3000 nominal rpm and 2.8 A (power supply is 230 V). Max torque is 9 Nm
    I was wondering if these caracterisics are suitable for carry the weight of roughly 200 kg (including platform and payload). I am planning on using them along with a planetary gearbox with a reduction ratio of say 40 or 50 and a lever arm of 140 to 160 mm.
    Thanks in advance
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    With a i-50 gearbox and 140mm lever you have 86,5kg force @ nominal torque (calculated with 90%gearbox eff.)
    It,s a bit on the low site with 200kg load.
    Look how much torque youre gearbox maximal can handle, most nema 32/34 planetaary gearboxes can handle 160nm max, and 50x 2,7 nm=
