Thoughts on this low cost linear actuator
Discussion in 'Motor actuators and drivers' started by Spit40, Jul 4, 2017.
  1. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    you need minimal 150 mm second
  3. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Thanks! Unless I DIY I guess SCN5's are still the best option then.
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    No scn5 are 10kg max
    far to week
    DIY actuators are cheap
    stong and fast actuators are expensife
  5. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
  6. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
  7. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I'm not the OP of that thread
    Ask @agroum
  8. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    thanks. Will do!
  9. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Just thinking this through more, most of the 6DOF builds I see here are pretty big affairs with I guess around 200cm between the tops of the actuators. As its all a case of angles, if I built something more compact at the top, say 80cm across, that would amplify the movement. Do you think such a design would then work with 80mm/sec actuators or was your 150mm/s based on a smaller setup anyway? I'm estimating an 80cm seat base lifted 80mm in one corner and dropped 80mm in the opposite corner would be around 12 degrees movement in a second, but I just don't know if that would feel responsive enough. I'm wondering if it might work for a light aircraft for example, but perhaps not a fast jet. Are there resources here which go into this more?
  10. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    Hi
    As fas i know there are no special recources for 6 dof
    12 degrees sec is slow, but 2 actuators fitted at one point lika a 6 dof becomes faster.
    It all in the angles, with a 200 mm stroke and 200mm/sec. actuator you can for axample create 250mm heave in a second
    regards Ad
  11. perdixero
    perdixero Member
    Argentina
    784Coins
