Thanos AMC1280USB
Discussion in 'SimTools compatible interfaces' started by Jerry Atrick, Jan 30, 2018.
  1. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi all has Thanos supplied a manual for the AMC1280USB, or did I miss it!:oops:
    I've sent mail him but, alas no reply.:(
    Regards Jerry.
  2. RandomCoder
    Control Engineer
    1,674Coins
    Hi Jerry,
    From what I gather Thanos is a little behind with the manual but has stated that the old manual 'mostly' still applies. All information to date is available on his site... http://motionsim.blogspot.co.uk/p/links-and-info.html
    Halfway down the page you will find the following paragraph....
    Regards,
    RandomCoder
  3. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi and thanks RandomCoder, I will take a peek at the PDF.
    Regards Jerry.
  4. GT3 Porsche
    GT3 Porsche New Member Gold Contributor
    Sydney
    271Coins
    i m using the amc on my 6dof rig plus Thanos was able to jail break the Chinese closed motion software {man is a genius}
  5. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    now it is possible with the new firmware and the new plugin to use all the AMC functions. I'm testing these days with the demo and lfs.
    I think very soon I will definitely go to simtools
    ora è possibile con il nuovo firmware e il nuovo plugin utilizzare tutte le funzioni della AMC. Sto testando proprio in questi giorni con la demo e lfs.
    Penso molto presto passerò definitivamente a simtools
  6. Dirty
    All the way up front.
    7,927Coins
    Hey :)
    Has a manual become available for the AMC1280 in the meantime? I am specifically looking for stuff on how to wire the limit switches and how to use sensors in Multiturn. I know there is a lot available in all kind of places/forums/blogs/dropbox, but I am REALLY missing a proper manual/documentation/tutorials.
    Help desperately needed!!!:sos
    Dirty :(
  7. Thanos
    Electronics Engineer
    United States
    2,830Coins
    You can wire limit switches for DC drives and AC VFD inverters that use DIR digital signals for direction. Not possible at the moment with sabertooth that only take 1 single unidirectional speed signal.
    Also i didn't make public in the firmware the multi turn code for SSI 12bit sensors, as it was a bit unreliable to detect full rotations in higher speeds. Instead i developed the Encoder2position module that reads quadrature encoders that can be placed in systems that require multiple turns (like servomotor linear actuators) and convert the output feedback to a 12bit analog signal ( finite 4096 positions).
    Thanos
