    Buy Download Package Now!
support ButtKicker and keyboard
Discussion in 'SimTools compatible interfaces' started by alpefe, Mar 29, 2013.
  1. alpefe
    alpefe Member
    - 17Coins
    hello, while reaching the rest of the parts for the brake mod (a sensor has already arrived), I've been doing a few other things, for some customers such as a keyboard stand variation that we already had, I wanted to be able to place front of the seat, not laterally, which remain securely attached and could then displace one side out of the way, so that it has been positioned and interlocked double joint at the other end, thus allowing great mobility, but same time once nestled, is solidly attached (goal achieved), I put some pictures.
    of course you can put horzontal or tilt for comfort.
    I've also done some other specific supports for other extras Buttkicker, in this case the client wanted to put 2 front and 2 rear units (seat), so that was solved with a profile of 40 to not tap the cockpit and anchored directly under the seat, and then some of duralumino machined solid bars, both front and rear, I put some pictures, when you have the client, you will put them.
    and good for today is what I have of news, although there is some more as a support seat, fully adjustable in height (to choose) and inclination, which I'll post pictures for the weekend, and also say to those who asked in his day , I have already begun asking motors and gearboxes for the movement system, I feel that many times it takes to do things, but I can not go faster, greetings.
  2. Ads Master
    Ads Master
  3. alpefe
    alpefe Member
    - 17Coins
    Well here I put some pictures of how the Buttkicker is installed, both front and back, the good of the grid is pudes you find the location you want.
    I hope you like it, greetings.
